Accord H22/H23 swap question Tried searching
Old May 24, 2006 | 10:19 AM
BoostedH23Accord's Avatar
Default Accord H22/H23 swap question Tried searching
Ok before anybody says search, I have tried but there is WAYYYY too much info on H22 and H23 swaps. (Kinda hard to search through) Anyway my questions are simple.
1. What PS bracket will work with the Accord PS pump and an H23 head.
2. Do I have to use a custom PS line (both Accord and Prelude)
3. Does anybody have the Bracket for sale?
Thanks.
Old May 24, 2006 | 02:24 PM
twistedbydezign's Avatar
Default Re: Accord H22/H23 swap question Tried searching (BoostedH23Accord)
SEARCH BITCH!!!!!
jk
i believe h/f series brackets will mount to each others motors, whether its dohc or sohc, this is based on 90-97 accords, but the h pump and f pump's line connections are different, you will either need to swap the entire line from the firewall to the pump on your lude to an accord one, take your lude line to a hose shop and have an accord fitting put on, or just ditch the power steering.....
as for the bracket, if u dont have one im sure you could get one for free somewhere, call around engine importers or shops in the area, sometimes they give entire f motors away for free, let alone just the power steering bracket that boosted cars will probably ditch anyways....or you could check to see if even a d or b series bracket will work, you just may have to get a different size belt
mongtite
Oct 19, 2008 12:19 PM
BoostedH23Accord
May 24, 2006 10:16 PM
machine4321
Apr 2, 2005 06:21 PM
tonezilla
Mar 18, 2004 10:36 AM
