jdm headlight turn signal wiring question?
Old May 24, 2006 | 09:31 AM
oranginal's Avatar
Default jdm headlight turn signal wiring question?
i searched and only could find how to wire the high/low beams.
but my question is about the corner parking lights:
on my drivers side light the corner bulb has 4 wires comming out (2 red , 2 black)
my passenger side only has 2 wires comming out the corner light (1 red 1 black)
so what are these extra wires for?
a diagram would be helpful if anyone could point me in the right direction.
sry for the large pics.
thanks!
Modified by oranginal at 1:50 PM 5/24/2006
Old May 24, 2006 | 10:20 AM
Hawkze_2.3's Avatar
Default Re: jdm headlight turn signal wiring question? (oranginal)
Somebady probably modified that harness so they could wire up some sidemarkers or something. As long as the plug still has only 2 connectors, you'll be able to just wire it up like normal with 1 red and 1 black wire.
Try to see how the wires go into the back of the connector and I bet you'll see the 2 reds go to the same place and the 2 blacks go to the same place.
Hope that helps...
Old May 24, 2006 | 10:23 AM
94Vtecluder's Avatar
Umm the corner bulb is exactly the same in both the JDM and USDM headlights? What kinda re-wiring are you talking about? They're both 194's...
Old May 24, 2006 | 10:27 AM
yoohoo's Avatar
Default Re: jdm headlight turn signal wiring question? (94Vtecluder)
just unplug it and plug in your oem bulbs! walla!
Old May 24, 2006 | 10:33 AM
Prelude_2_NV's Avatar
Default Re: jdm headlight turn signal wiring question? (Personal Information)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Personal Information &raquo;</TD></TR><TR><TD CLASS="quote">just unplug it and plug in your oem bulbs! walla!</TD></TR></TABLE>
This is what I would do.
Old May 24, 2006 | 12:20 PM
Lil. Cease's Avatar
Default Re: jdm headlight turn signal wiring question? (Prelude_2_NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">Umm the corner bulb is exactly the same in both the JDM and USDM headlights? What kinda re-wiring are you talking about? They're both 194's...</TD></TR></TABLE>
yup, mine plugged right in....
Old May 24, 2006 | 12:47 PM
oranginal's Avatar
thanks to all
Moto DC2
Lighting
Dec 19, 2007 07:37 AM
pbizzlegsr
May 21, 2006 07:45 PM
bodazappa
Jun 13, 2004 03:12 PM
Carlo
Oct 2, 2003 10:03 AM
