Another 600+whp LS w/GT35R build in EG Hatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si »</TD></TR><TR><TD CLASS="quote">sweet looking setup. 600whp is gonna take a lot of boost with that LS head tho
My LS head made 500whp on 19lbs on pump gas.
tannerLSt should be deep int he 600s with race gas.
I said it once, I'll say it again... the LS's are coming on strong this year.
</TD></TR></TABLE>My LS head made 500whp on 19lbs on pump gas.
I just realized that B18A/B blocks have the head dowl pin on the intake side and the B18C1/5 blocks have the dowl pin on the exhaust side. So says the service manual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">Those pistons dont look thermal coated. Who did it the coating?</TD></TR></TABLE>
only coated on sides
thinking maybe 25-27lbs of boost should get 600whp
</TD></TR></TABLE>thinking maybe 25-27lbs of boost should get 600whp
You dont need that Pro1 damper at all with the hasport mounts. Its just a wast of money, weight and space.
Id have to say I think your rods are the weak spot in the mix. It will defentally be a sick setup.
Post the plots once its tuned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt »</TD></TR><TR><TD CLASS="quote">only coated on sides</TD></TR></TABLE>
Thats not a thermal coating buddy. Thats a friction reducing moly coating applied to all Wiseco pistons.
THIS is a thermal coating on the top and moly on the skirts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">Maybe it's just the angle of the picture... but the pistons almost look like they are in backwards.</TD></TR></TABLE>
I'm almost positive those are in backwards. Maybe it has been fixed since the picture though.
Great looking build. Cant wait to see it lay down some track times
600whp should not be hard. We've made 580 with the stock fuel line in my car, we've been lazy and not done line upgrades in the car. We also turn the engine 9000 rpm all last season with no problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19sec beast »</TD></TR><TR><TD CLASS="quote">
I said it once, I'll say it again... the LS's are coming on strong this year.</TD></TR></TABLE>
Yes sirrrrrrr! Geez guys i feel so left out. i started up my forum and havent gotten this much love. LOL good luck tannerlst and 19secbeast. i hope to be dyno in 2 to 3 weeks. pushing to 9500 and 35psi only a 3.5 bar map ( yeah i need a 5 bar )
dont mean to thred jack but feeling the lst luv so heres my link
https://honda-tech.com/zerothread?id=1632057
tanner if you want if of let me know i have no problems taking that out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T »</TD></TR><TR><TD CLASS="quote">get another wastegate! It's not goin gto cut it. We will see what that head handles.....good luck tanner</TD></TR></TABLE>
i'm hoping if i run enough boost the wastegate will be ok, the head should hold up pretty well
it's not going be sufficient. go ahead and get the 44mm before you get to far in it. Im only going to be at 450ish but It's a neccesity when you reach that horsepower. Do it now.
Not saying it can't be done but........u know how this stuff goes tanner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T »</TD></TR><TR><TD CLASS="quote">it's not going be sufficient. go ahead and get the 44mm before you get to far in it. Im only going to be at 450ish but It's a neccesity when you reach that horsepower. Do it now.
Not saying it can't be done but........u know how this stuff goes tanner</TD></TR></TABLE>
if its not enough i'll get bigger, until then i'll keep what i have, changing a wastegate is nothing
Not saying it can't be done but........u know how this stuff goes tanner</TD></TR></TABLE>if its not enough i'll get bigger, until then i'll keep what i have, changing a wastegate is nothing
