Anyone Running 235 tires or higher? (5th gen)
Old May 24, 2006 | 06:49 AM
classified's Avatar
Default Anyone Running 235 tires or higher? (5th gen)
Anyone running 235 wide tires or higher on their 5th gen? I'm lowered 1.25inches with a 48+offset 17x7.5 wheel and I'm wondering if 235/40 tires will fit on my car? Also does anyone have any pix of these size tires installed?
Old May 24, 2006 | 07:24 AM
InvaderTrax's Avatar
Pretty sure 225/40(or 45, don't remember) will fit. Not sure about 235
Old May 24, 2006 | 07:30 AM
prelude1897's Avatar
Default Re: (InvaderTrax)
I believe the highest you can go is a 225 series.
Old May 24, 2006 | 08:32 AM
PrecisionH23a's Avatar
Default Re: Anyone Running 235 tires or higher? (spirctsae)
I had a 225 on my 4th gen last year... they were pretty beefy.
Old May 24, 2006 | 08:39 AM
HxClude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spirctsae &raquo;</TD></TR><TR><TD CLASS="quote">Anyone running 235 wide tires or higher on their 5th gen? I'm lowered 1.25inches with a 48+offset 17x7.5 wheel and I'm wondering if 235/40 tires will fit on my car? Also does anyone have any pix of these size tires installed? </TD></TR></TABLE>
235/40/17 will fit on a 17x8 rim +48 offset. You can't be dropped more than 1.5" though. Several PreludeOnline members run or have run that setup. I think Monk3y on this board has. The offset is critical and +48 seems to be the sweet spot. Currently the SSR Competition and OZ Ultraleggera are the only two wheels I know of in that size and offset unless you do a special order from Volk or Work.
I have a few pics of 235/40/17 on SSR comps if you want to send me your email.
By the way, 7.5" is considered too small by all the tire manufacturers to safely run a 235/40/17 - 8" in minimum. It may fit on a 7.5" but if it fails you have no legal recourse.
Old May 24, 2006 | 10:56 PM
phryxis's Avatar
you are right.
235/40/17 with 17x8 +48 offset fits.
I have Monk3y's rims. They are rota torques.
Old May 25, 2006 | 01:12 AM
Buffalo's Avatar
Default Re: (phryxis)
I run 215/40 on a 17x7" wheels but i've run even 225/40 on the same 7" wheels in the past with no problem so i suppose a 235/40 tire will fit fine an 7,5" wheel.
Old May 25, 2006 | 08:19 AM
Techna600f4i's Avatar
Default Re: (Buffalo)
205's In front 225s in rear
AP1 Wheels
Old May 26, 2006 | 04:01 AM
AZprelude's Avatar
i ran 225/40 by 8 1/2 on my lude and when i droped down to 16's again it was as if i took a freakin second of my acceleration. by the way the rsx 16's look pretty good on preludes. thats what i have on now
thegamettt
Mar 26, 2007 03:46 PM
jardolei
Nov 28, 2006 12:29 PM
kryptic
Aug 7, 2006 06:55 AM
MilltownLudeGrl
Mar 9, 2004 06:10 PM
