crx transmission spline question
Old May 24, 2006 | 06:48 AM
tractiondeprived's Avatar
Default crx transmission spline question
the transmission in my 91 crx si has been grinding, clutch is bout to go out, so my buddy gave me his transmission off the a6 motor that used to be in his rex (88 si)... i would like to use the spec clutch and fidanza flywheel off of my civic (95 ex)'s old transmission, but from my understanding the 88 trannies had a 22-tooth spline instead of a 21 on the later ones, so i would need to find another clutch disc... is this true, and if so, would it be easy enough to take the spline out of my 91's transmission and swap it for the one in the 88 model transmission?
Old May 24, 2006 | 08:12 AM
Tyson's Avatar
Default Re: crx transmission spline question (tractiondeprived)
yeah, splines are different so youll need a matching 88 disc.
flywheels are different too but the old flywheel will work too.
its not that simple to switch input shafts if youve never opened a tranny before. but its certainly possible.
ls19integra95
May 4, 2007 03:21 PM
aj_zo
Jun 15, 2006 08:04 AM
Ecugrad
Jul 15, 2005 05:31 AM
LASSEN768
Aug 10, 2004 10:46 PM
lscrx
Jan 4, 2004 07:32 PM
