Disabling EGR on a h22a?
Old May 24, 2006 | 05:04 AM
djnikko's Avatar
Default Disabling EGR on a h22a?
I have managed to break my EGR sensor on my h22 engine so I had a thought about disabling this. Does anyone know how I can go about doing this?
Also do you know where I could find a EGR sensor other than honda? Just incase I want to put it back to standard sometime
Thanks in advance
Old May 24, 2006 | 12:03 PM
lude of pre 2.3's Avatar
Default Re: Disabling EGR on a h22a? (djnikko)
well you can pry find one at an honda/import slavage yard. The EGR only works during cruise to reduce NOX levels (heat) you could fab a plate to just block it off and just bolt the EGR back on so it looks stock if your in an emissions area
Old May 24, 2006 | 12:10 PM
BB6racer's Avatar
https://honda-tech.com/zerothread?id=1565091
i remembered this thread from a while ago. Qveon is really good at this kind of stuff, PM him or me if you need more help. his little realy will work for an OBD-1 ECU, and i figured out how to do it on an OBD-2 ECU, just never got around to actually buying all the parts and putting it together.
Old May 30, 2006 | 06:07 AM
AZprelude's Avatar
don't do it
Old May 30, 2006 | 06:18 AM
Option2BB6's Avatar
Def let us know how you can wire it up to work on OBDII, that'd be excellent!
Old Jun 1, 2006 | 06:19 AM
djnikko's Avatar
Default Re: (Option2BB6)
The h22 is going into a OBD0 wired CRX the h22a I have is OBDI. I am using a complete standalone management system called DTA Fast S60.
I found a guide here http://www.92lude.com/egr_mod.htm to remove it but think I am going to get a CEL depending on how my standalone engine management works. Im pretty sure it shall have a feature allowing me to disable it.
I'll let you know how I get on.
Old Jun 1, 2006 | 08:18 AM
GlenWatkins's Avatar
Default Re: (djnikko)
You mean the gizmo on top of the EGR valve that confirms the opening of the valve ??
Those would be specific for the EGR valve.
asmallsol
Oct 2, 2023 07:13 PM
Sungsu
Apr 14, 2010 04:06 PM
ib042129
Nov 4, 2008 01:31 PM
JBirch_97Prelude
Feb 20, 2007 12:13 PM
Dred
Apr 10, 2006 02:58 PM
