Honda S2000 Honda S2000
tires on stock 16" rim
Old May 23, 2006 | 10:53 PM
import_love's Avatar
Default tires on stock 16" rim
would this size tires fit on stock rims on a 2001 s2k without rubing and be safe to drive on
225/50/16 front 245/50/16 back
Old May 23, 2006 | 11:36 PM
- BSeRiouS -'s Avatar
Default Re: tires on stock 16" rim (import_love)
you should stick with the recommended stock sizings with stock AP1's. The rear 245, and the front 205.
Old May 24, 2006 | 12:08 AM
Mr. Projekt's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by import_love &raquo;</TD></TR><TR><TD CLASS="quote">
225/50/16 front 245/50/16 back</TD></TR></TABLE>
The rears should be 245/45/16. And yes, they would fit.
Old May 24, 2006 | 08:11 AM
well the stock size is 205/55/16 front and 225/50/16 in back i just dont want the tries being to wide for the rim being that i want to put 225/50/16 in front and 245/50/16
Old May 24, 2006 | 08:18 AM
Nishant's Avatar
You can run 225/50/16 in the front as long as you're not on stock suspension and not too low.
As per the rear, the OEM rear SO2 tire in 225/50/16 is wrongly measured. If you measure it, you will see that its actually 245/45/16. So when you buy any other tire besides the S02, you must get 245/45/16. If you do not, you will be losing grip.
When the S02 tire was released, there were 3 different versions of the 225/50/16 size. One was the regular size, then there were two specificly made ones. One was for a porsche boxster and the other the s2000. If you had all 3 of these side by side, you would see that all 3 were different. I know its weird considering the size is printed on the sidewalls but this was not the case. Each tire was different in size.
Old May 24, 2006 | 09:40 AM
jdm93cx's Avatar
Default Re: tires on stock 16" rim (Nishant)
[QUOTE=Nishant]You can run 225/50/16 in the front as long as you're not on stock suspension and not too low.
I agree
Old May 24, 2006 | 11:39 AM
Nishant's Avatar
Default Re: tires on stock 16" rim (jdm93cx)
You can actually run a 225/50/16 on the front with stock suspension but you need a stiffer front swaybar to avoid rubbing
Old May 24, 2006 | 11:46 AM
* B A N N E D *
225s all day, 255s some days.
Old May 24, 2006 | 11:47 AM
Nishant's Avatar
Default Re: tires on stock 16" rim (FR-MOB: Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">225s all day, 255s some days. </TD></TR></TABLE>
not on the front 16"
Old May 24, 2006 | 12:09 PM
* B A N N E D *
Oops. Not thinking about anything except my car right now. Selfish, I know.
225s will be fine. I've never seen them rub, stock or close to it. If you're slammed, get off the OEM wheels!!!
Old May 24, 2006 | 03:44 PM
silentdancer's Avatar
wouldnt the speedo be thrown off if you ran a 50 instead of the recommened 45?
Old May 24, 2006 | 09:08 PM
* B A N N E D *
Default Re: tires on stock 16" rim (trejap1)
The extra tire width makes up for the shortened sidewalls in most cases. What matters in the end is rolling diameter. Tirerack posts these in their specs. From the factory, the S already has a bigger front rolling diameter than rear anyways.
Old May 25, 2006 | 01:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trejap1 &raquo;</TD></TR><TR><TD CLASS="quote">wouldnt the speedo be thrown off if you ran a 50 instead of the recommened 45?</TD></TR></TABLE>
i don't think i'll be that much of a difference to throw it off.
bb2prelude
Jul 29, 2007 01:55 AM
Agent Zero
Honda S2000
27
Mar 20, 2007 03:32 AM
3vilMonkey!
11
Jun 26, 2005 05:14 PM
slowacura
Nov 13, 2003 08:44 AM
02 coupe
16
Aug 27, 2002 03:12 PM
