Got a 1976 CB 500... look trying to restore it
Old May 23, 2006 | 10:20 PM
chuniepatuni's Avatar
Default Got a 1976 CB 500... look trying to restore it (I GOT PICTURESS) Updated 5/24/06
Ok my dad was in the military and then he met my mom.. :sigh:... Well when he was in the military in like the 70's he bought this bike.. Then he married my mom.. and then they got a kid and he never rode the bike.. its been sitting on our side year for roughly ten years now.. so far i know we need to clean the caburator (spelling!!) and the gas tank possibly even get a new one... and get a new key thing.. he lost his!!!! DOH!!!! Ok i know nothing about bikes... im a car kinda guy buy since gas prices are so high!! why not get a bike we have work!!!... So i dont know anything but i want to make it run.. ill try to get pictures up by tomorrow to give u guys a visual!! thanks for all ur help!! (its late and i have school so dont know how i wrote... dont even know if it makes sense!!) anyways summary... 1976 CB 500 (honda).... hasnt been ridin for roughly 10 years.. just need help to get it running!!! thanks al!!!
Had to post this up for laughs!! HAHAHAHAHA
my brother n friend make me giggle *giggle*giggle*giggle*
Modified by chuniepatuni at 4:57 PM 5/24/2006
Old May 23, 2006 | 10:26 PM
marmaladedad's Avatar
Step 1: Take the MSF
Step 2: Buy a service manual of some sort for your motorcycle
Step 3: Buy gear
Step 4: Come back to HT to a resounding hurrah and congrats...but not until after 1-3.
As for getting the bike to run, if it's been sitting for ten years, you'll probably have a TON of rust to clean out of the carbs, fuel line, and gas tank. You'll need a new battery and DEFINITELY new tires and brake pads (or shoes if they're not disc brakes). Change out all the old fluids for new stuff.
Old May 23, 2006 | 10:35 PM
ok... ill take pictures of all the rust.... and stuff!!!
Old May 23, 2006 | 11:18 PM
CRXDrew's Avatar
sounds like a potentially fun project depending on how mechanically inclined you are.
Rust is your enemy.
Old May 24, 2006 | 07:01 AM
Gary the no trash cougar's Avatar
Pick up your trash!!!!
Default Re: (CRXDrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marmaladeboy &raquo;</TD></TR><TR><TD CLASS="quote">Step 1: Take the MSF
Step 3: Buy gear
don't do any of that stuff yet.
Item number 1 is get the bike running. First thing is see if the motor is locked up. Im assuming your battery is dead after sitting for 10 years. Either buy a new one or hook your bike up to a car battery via jumper cables(don't run the car as the alternator will put out more amps than you want) try to turn over the engine. Make sure there is oil in it. If it turns over then great if it does nothing try to turn it over by hand. Pull off the motors left side(i think left) cover and try to turn it over that way. It helps if you pull the spark plugs and put a tiny bit of oil in each cylinder. If it turns over then great. Next thing is pull the carbs and clean them obviously. Use gumout and compressed air to clean them (2 important things wear some kind of glasses because carb cleaner in the eyes sucks and make sure not to soak rubber peices in carb cleaner because it will eat them) Pull off the float bowls and clean out all the gunk. Make sure the floats can move freely, take them off and make sure the float needles are pointy and clean as well as the seat for them. Clean out all the jets and the diaphram. Be especially careful with the diaphram as they are very expensive to replace. There are many carb rebuild kits available on the web if you need help pm me and ill post some links. Next, Check the tank for internal rust and junk. You can buy a tank sealer kit from por15 that will fix that or take it to a radiator shop and they will fix it for you. Don't use kreem, I repeat do not use kreem unless you plan to sell the bike in a year. If the bike sat with gas in it then change your fuel lines. Make sure the petcock is operational. After all of that change the fluids put everything back together and try to start it. You may have electrical problems if you had to turn it over by hand. After you get it running synch the carbs, new tires, and some other stuff you should be on the road.
Then do the msf and all that stuff.
Old May 24, 2006 | 02:11 PM
i dont know what msf is.. i also dont know how to turn the engine over.... well atleast not the way ur prolly thinking! haha well anyways im not mechanically inclined... as i told u guys before i know NOTHING about motorcycles... Keep them comeing and hopefully i will get it running... i will pst pictures on how im doing.. ill take pictures rihgt now of how it sits... then show u guys!! THanks alot specially u Jack!!
Old May 24, 2006 | 02:34 PM
Default Re: (chuniepatuni)
msf is a safety course
Try to crank the bike if it turns over you will hear it trying to crank.
Old May 24, 2006 | 03:43 PM
ok... so wen i kick the pedal... it should make a noise if it doesnt then it doesnt turn over??? btw will honda give me a key for it??
Old May 24, 2006 | 03:58 PM
pictures are up!!!!!
the bike cranks its just a bit stiff tho... hurt myself doing it...
Old May 24, 2006 | 05:08 PM
92civeg's Avatar
Default Re: Got a 1976 CB 500... look trying to restore it (I GOT PICTURESS) Updated 5/24/06 (chuniepatuni)
i recently went through the same situation with a 1975 cb360 i acquired...anyway this website helped me out a lot http://dansmc.com/
here is a pic of it..and good luck to ya
Old May 24, 2006 | 05:57 PM
Default Re: Got a 1976 CB 500... look trying to restore it (92civeg)
if the kickstart will move then the motor is not locked up which is wonderful. It will be hard because it has sat for so long. Make sure you check the oil. I cant stress this enough because you don't want to work on something just to have it blow in your face because you missed something simple. Take off the carbs and clean them now along with the gas tank and new fuel lines.
It would be alot easier just to order a new ignition of ebay with keys than try to get them from honda.
http://cgi.ebay.com/ebaymotors...wItem
There you go
Old May 24, 2006 | 07:22 PM
Alright... im planning to clean the carbs tomorrow... i noticed that the 2 carbs are running into those 2 little bucket things.. on the side where it says cb500t... just wondering what thoese things were... And also about the key on ebay... what about the ones for the seat and the gas tank??? thanks alot guys!!!
Old May 24, 2006 | 08:05 PM
sup gurl's Avatar
Default Re: (marmaladeboy)
Step 3: Buy gear
Step 5: Delete that last picture for your own sake.</TD></TR></TABLE>
Edited for OP.
Old May 24, 2006 | 08:34 PM
Default Re: (sup gurl)
yeah i wasn't thinking about the other locks, in that case get a locksmith to do it or see what honda can do for you.
Old May 24, 2006 | 08:35 PM
CRXDrew's Avatar
Damn... carbs are gonna need some love. Also those fork seals are gonna be dead. I think after the tubes get pitted with rust it'll need to be replaced. Good Luck
Old May 24, 2006 | 08:39 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sup gurl &raquo;</TD></TR><TR><TD CLASS="quote">Edited for OP. </TD></TR></TABLE>
LMFAO
Ahh...youth...
Oh, and that is NOT the correct fusion technique.
Old May 24, 2006 | 09:34 PM
hahaha... so the forks are useless??? or what?? so do i need new forks.. i just want it running... basically to teach me how to ride maybe get me to school n back
Old May 25, 2006 | 07:26 AM
BiffStroganoffsky's Avatar
I would remove spark plugs and put some lightweight oil in and let sit for a while. Crank it over a few time with the plugs out to help lube the walls. Have the carbs rebuilt. Have the forks rebuilt or cleaned and seals and oil and all the rusty stuff replaced...eh, just have them rebuilt. Replace the chain. Check the rear shocks and replace if there is no life left. Drain the gas tank and inspect. If not leaking, rinse with new stuff and flush. Put a new filter in and maybe a petcock if that is gunked up beyond cleaning. Drain and replace oil and oil filter. Get a new battery and plugs and see if she starts.
If she does, you can come help me with the Magna.
Old May 25, 2006 | 07:51 AM
p nut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chuniepatuni &raquo;</TD></TR><TR><TD CLASS="quote"> what about the ones for the seat and the gas tank??? thanks alot guys!!!</TD></TR></TABLE>
On my bike, there is a code on the bottom of the ignition (you have to take it off in order to see). Take that to Honda and they can cut you a key.
Old May 25, 2006 | 07:55 AM
CRXDrew's Avatar
the top part of the fork... the one that slides inside of the other needs to be dead smooth. The oil seal rides on the tube and I believe if the tube is badly pitted it will break the seal if its not already. Bottom part should be fine, probably just needs a new oil seal. You can pick those up on ebay for pretty cheap.
cyco
Honda Motorcycles
17
May 15, 2008 12:25 PM
jdmEnrique
Honda Motorcycles
Jul 20, 2007 01:43 PM
1Bar GSR
Honda Motorcycles
13
Apr 19, 2006 07:49 PM
CrAzyGsR101
Honda Motorcycles
Sep 1, 2004 09:42 AM
vjace
Honda Motorcycles
Aug 9, 2004 03:34 PM
