CRX SI distributor on CRX LS
Old Apr 12, 2002 | 09:33 PM
CimorelliCRX's Avatar
Default CRX SI distributor on CRX LS
My question is will a CRX SI distributor bolt right up and work fine on an LS in a CRX? Its a b18a1. Its non obd. I have been told it will, just making sure.
Old Apr 12, 2002 | 10:58 PM
RexB16's Avatar
Default Re: CRX SI distributor on CRX LS (CimorelliCRX)
i seriously doubt thta it will, crx is a SOHC while ls is DOHC and i am sure that makes a huge difference. also i think the input key is a dirrefent size and i know that all of the bolts wont line up. juts go buy an ls dist from checker. $109 ownz j00.
Old Apr 12, 2002 | 11:01 PM
dustin's Avatar
Not gonna work.
Old Apr 13, 2002 | 07:56 AM
Default Re: CRX SI distributor on CRX LS (dustin)
alright thanks guys.
Old Apr 13, 2002 | 10:56 PM
flat-blk-HB's Avatar
yes it will work!i had a friend run a D16A dizzy on his 91 LS..only one bolt hole lines up but it will work!
Old Apr 14, 2002 | 12:43 AM
dustin's Avatar
Default Re: CRX SI distributor on CRX LS (89EF-BCUMBIE)
well if that counts as "Works" then I guess it works... 1 bolt hole doesn't cut it because it is easy for it to get tweaked...
Old Apr 14, 2002 | 12:59 AM
dumbchild's Avatar
it works, i think you can even line up two holes if you bore one out a bit. I ran the CRX distrib. on my B18C1 for awhile but it pretty much sucked(SOHC vs. DOHC). put on a JDM B16a distrib.- million times better
Old Apr 14, 2002 | 08:49 AM
balistic CRX's Avatar
Default Re: CRX SI distributor on CRX LS (dumbchild)
I put my 90 crx hf distributor on my zc motor. It works pretty good but its only one bolt holding it together. But im thinking of getting the right distributor for it.
Old Apr 14, 2002 | 11:31 AM
Default Re: CRX SI distributor on CRX LS (balistic CRX)
he wanted to know if it would work.right?i didn't mean it would be the best way to go but it will work for the time being.
88EDHatch
Nov 13, 2010 07:48 AM
sil99civic
Feb 24, 2004 06:47 PM
blayzenazn
Mar 23, 2002 11:14 PM
ViperRedCRX
Mar 10, 2002 06:17 PM
