Koni Yellows... are there parts missing?
Old May 23, 2006 | 05:28 PM
Seeds's Avatar
Default Koni Yellows... are there parts missing?
I just got koni yellows for the rear on my 94 accord sedan. When they came in the only thing that was in the box was the adjuster, the shock, and the spring perch. None of the stock hardware fits the konis... obviously since the shaft is larger... I understand this. What I need to know is what was left out of the box? The company I got them from isnt being real co-operative. Any input at all would be greatly appreciated.
For anyone who wants to know, I bought the shocks from 4myride.com... a big 0 of 5 stars for them!!
Old May 23, 2006 | 09:49 PM
pos_cd5's Avatar
Default Re: Koni Yellows... are there parts missing? (Seeds)
i think it came with everything it should come with. this is a common problem, my firend got koni yellows for his BMW and the larger diameter required him to get his gland nuts machined to accomodate the size of the knois. so maybe something similiar is going on with your accord, not sure how to solve your problem though, but bump for hopes of someone who does will help you
Old May 23, 2006 | 10:31 PM
Mewgen's Avatar
You have everything you have the snap-ring attached to the struts. You should cut the bumpstop in 1/2 and use only 1 1/2" of the oem shock cover. You will also have to drill out the the shock cover so it fits. Everything should fit since I installed mine 2 weeks ago. Anymore questions, just ask. Koni's are awesome.
Old May 23, 2006 | 10:32 PM
Mewgen's Avatar
Default Re: Koni Yellows... are there parts missing? (Mewgen)
Also, there should be a bag of washers & nuts for the new strut bushings.
Old May 25, 2006 | 11:43 AM
Seeds's Avatar
A bag of nuts and washers... I knew it, there trying to claim that there was nothing.
mish__
Suspension & Brakes
Jul 9, 2010 10:51 PM
Undercover_Skank
Aug 30, 2004 12:55 PM
gsr-mike
Jun 18, 2004 05:55 PM
IN2VTEC
May 5, 2003 01:07 PM
taytay333
Mar 26, 2002 03:54 PM
