06 Accord witn Navigation - can't replace rear speakers?
Old May 23, 2006 | 04:55 PM
cavr6's Avatar
Default 06 Accord with Navigation - can't replace rear speakers?
Rear speakers are weak.
I want to upgrade them. Dealer says they can't be upgraded due to the magnet interfering with the nav gyros. Rear oem speakers have tiny magnets.
I want to put in new JBL's that have much larger magnets.
I don't want to jack up the nav system and I want to updgrade the speakers.
Any suggestions?
Modified by cavr6 at 9:39 PM 5/23/2006
Old May 23, 2006 | 07:48 PM
japanesecar's Avatar
Default Re: 06 Accord witn Navigation - can't replace rear speakers? (cavr6)
Infinity makes some good magnetically shielded speakers. They may be worth a try. Or, depending on how much work/money you want to put into it, NXT makes flat panel speakers that you can relocate to the reardoors or almost any other place (The New Toyota FJ cruiser has them built into the ceiling panel).
Old May 23, 2006 | 08:28 PM
cavr6's Avatar
Default Re: 06 Accord witn Navigation - can't replace rear speakers? (japanesecar)
That's a good idea.
I'm going to attempt to post a picture of the speaker magnet. It is seriously small.
What unit/model Infinity are you referring to? Crutchfield didn't carry any when I called this afternoon.
Thanks...
Old May 23, 2006 | 11:49 PM
AFAccord's Avatar
Just an FYI... Magnet size DOES NOT determine a speaker's potential.
Old May 24, 2006 | 09:31 AM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: 06 Accord witn Navigation - can't replace rear speakers? (AFAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AFAccord &raquo;</TD></TR><TR><TD CLASS="quote">Just an FYI... Magnet size DOES NOT determine a speaker's potential.</TD></TR></TABLE>
You can do it just be sure that you get the shielded speakers as stated above. The magnet radius is pretty close to a quarter size but replacing them isn't going to give you "a world of difference" I would reccomend using a small inline amp to help it out some if your looking for better power.
Old May 24, 2006 | 11:17 AM
cavr6's Avatar
Default Re: 06 Accord witn Navigation - can't replace rear speakers? (MooGoCow3)
Do you have a rec on which inline amp to get?
Old May 25, 2006 | 01:05 AM
If I remember correctly all of the Infinity Kappa series are shielded speakers. You could also go the route of marine speakers, which are almost all shielded so as not to interfere with the boats navigation system.
Defcon2030
Dec 10, 2005 08:53 PM
kbanks45
Sep 20, 2005 10:19 PM
93Accord2.2
Sep 7, 2004 10:15 AM
rev4mebaby
Jan 14, 2002 04:59 PM
pauken
Jul 31, 2001 10:26 PM
