where is the ecu jump connector to check codes on 95 prelude vtec?
Old May 23, 2006 | 04:10 PM
SrT4u2nV's Avatar
Default where is the ecu jump connector to check codes on 95 prelude vtec?
where is the ecu jump connector to check codes on 95 prelude vtec? I read that it is behind the center console. Im unsure exactly where i seen an orange connector that doesnt connect to anything.
Right now my problem is no start with no spark after timing belt, water pump, head gasket, cam, spring and retainers install. anyone know why?
Old May 23, 2006 | 04:29 PM
eg6r0ll
Guest
Posts: n/a
Default Re: where is the ecu jump connector to check codes on 95 prelude vtec? (SrT4u2nV)
Yeah I'm wondering too.
Old May 23, 2006 | 04:47 PM
Jagan'92's Avatar
driver side under the console, it's blue and two prong.
It should be right beside the orange one you found
http://www.92lude.com/diagnose_error_codes.htm
Old May 24, 2006 | 02:41 AM
SrT4u2nV's Avatar
thanks Jagan for the post. Ill find it later hopfully.
dcskater56
Dec 21, 2009 05:27 PM
accord03coupe
Feb 10, 2007 12:48 AM
