timing belt and BC4's
Old May 23, 2006 | 04:06 PM
pornstar4777's Avatar
Default timing belt and BC4's
which timing belt should I go with? Does anyone know where has toda timing belt in stock?
its for a stroked B16B motor to ITR specs
happy tuning
P-star
Old May 23, 2006 | 04:41 PM
Default Re: timing belt and BC4's (pornstar4777)
come on guys.....anyone?
Old May 24, 2006 | 08:13 AM
YumVTEC's Avatar
b16b is just a de-stroked ITR motor. the distance from the timing belt gear on the crank to the cam gears is the same between both b16b and b18c. so to answer one of your questions, you can run a b18c1/b18c5 timing belt. go to your dealer and pick one up, unless you just have to have the toda part.
Old May 24, 2006 | 08:44 AM
Eva01's Avatar
I'd say AKH, the US distributor for Toda, probably has them in stock. http://www.todaracing.com/prod....html
Old May 24, 2006 | 09:22 AM
wildoutwhitegsr's Avatar
or use a greddy timing belt or Power Enterprises (PE)
Old May 24, 2006 | 05:09 PM
Default Re: (wildoutwhitegsr)
thanks guys
bet_88
Sep 7, 2006 02:49 PM
pornstar4777
May 23, 2006 05:43 PM
allmotorhatch
Jun 8, 2003 05:57 AM
Eric R
Aug 3, 2002 02:44 AM
