Can a 2000 integra...
Old May 23, 2006 | 02:59 PM
supperfly17's Avatar
Default Can a 2000 integra...
Stock cd player/deck be installed into a 95 accord 4 door lx.
And what kind of things do i need, just the harness or?
Thanx for the help guys.
Old May 23, 2006 | 03:50 PM
iam7head's Avatar
Default Re: Can a 2000 integra... (supperfly17)
it will not be a plug and play, honda changed their harness system at 98 and at 06
you'll need the harness from the cd player, and you need a color code for your year of accord.
30 minute job if you solder everything
Old May 23, 2006 | 04:03 PM
Default Re: Can a 2000 integra... (iam7head)
ok so pretty much the hardest part is connecting the wires right, even though there is a tape deck in the accord now, as long as i connect the right wires to the cd player deck from the integra it should work right?
Old May 25, 2006 | 07:23 AM
89a6T's Avatar
easier way...go to junk yard and get harness for the integra then get harness for accord just like if you were doing a aftermarket radio.
Old May 25, 2006 | 08:59 AM
Truv603's Avatar
wait are the colors matched on all years of hondas and acuras or do you need the manual to find what wires are compatible?
Old May 25, 2006 | 01:43 PM
Black Ex Coupe's Avatar
I thought all honda vehicles 98 and up had a different harness also, so when I wired up my friends headunit for his 2000 integra gs with the 98+ harness and pulled out his deck I found that it was the same harness as my 93 accord.
Also in my other friend's 2000 gs-r it has the same harness as my accord and I used his headunit for awhile until I went aftermarket.
Old May 25, 2006 | 07:46 PM
silentone's Avatar
Default Re: (Black Ex Coupe)
Worst case senario youre gonna have to cut and match wires. Right speaker to right speaker, power to power, left speaker to left speaker... etc. Easy stuff should take about an hour for a beginner.
thadon805
Sep 17, 2016 11:31 AM
414teg95ls
Jan 28, 2008 08:50 AM
95ejjj
Nov 26, 2005 12:48 PM
ahh sanga
Audio / Security / Video
Jul 16, 2004 06:49 AM
kickdown
Dec 1, 2001 12:43 AM
