ne1 know if replacing a driverside window is risky job.
Old May 23, 2006 | 02:56 PM
HatefulDjiN's Avatar
Default ne1 know if replacing a driverside window is risky job.
i have 94' accord lx with an h22a swap .some other extras and my car was recently broke into . after some time thiinking i came up with an idea to fix the window myslef rather than paying to get it done .since the window itslef cost close to nothing compaired to gettingit done by a shop. so if anyone know sany tips or advice id appreciate it . thankz..
Old May 23, 2006 | 03:14 PM
92ehatch's Avatar
Default Re: ne1 know if replacing a driverside window is risky job. (HatefulDjiN)
its really easy.
take off door panel
take off plastic thing covering door
roll window down until you two bolts holding the window onto the window regulator are accessible.
unbolt
pull window out (or if yours is broken, pull little plastic pieces with glash shards attached to it out)
install is revers of removal
i removed my window that way and i had never done it before. you will understand once you try it.
not even worth thinking about letting a shop do it
JDMgunmetalCRX
Mar 31, 2009 08:50 AM
kelviiv
Paint and Body
Apr 30, 2008 08:24 PM
Knightmare69
Apr 24, 2006 09:24 AM
Wazup
Sep 23, 2003 03:51 PM
SlammedHatch90
Jan 31, 2003 03:49 PM
