Need exhaust help
I have a 3inch catback for my '97 teg. I'm going to add a 3inch flex pipe to it. Well i'm going to be hooking it up to the stock manifold. I beleive the collector is 2.25inch (not too sure). What else would i need to do this? some step down connectors, and a flange? What size flange and where should i but them from? Sorry, im a newb to exhaust. TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 »</TD></TR><TR><TD CLASS="quote">you need a reducer, check out this website.
http://stores.channeladvisor.c...ucers/</TD></TR></TABLE>
Great site. Thanks alot!
but i just started thinking....if i have a 3in flex pipe and have it go down to 2.25 it would probably be hard to get bolts in there....should i go with a 2.5in flex pipe?
Well I have advice, but I'm not sure where you're putting it exactly. If its NA, a 2.5" won't be an issue (usually a bit under the rated size between the mesh walls). If it was me and a perminant fix, I'd go with 2.25" or whatever fits, then have the end flare to fit the 3".
What I was thinking about doing for my exuast to swap to stock easily: take the 3" exhaust I made [3" flange is 4" behind the oem cat's rear flange], make a 3bolt cat to 3bolt 3" adapter, then slap the adapter on the stock mani/collector/cat to bolt right up. Doing this on yours will make it not fit on other cars w/o modding. I project mine to rust out in 2 years, so I dont care about mine.
THEDirtyDseriesWOOT
Welding / Fabrication
14
Dec 11, 2007 07:50 AM
poorman's type-r
Jul 8, 2007 08:44 PM
MidwestAutoWorks
43
May 3, 2007 08:22 AM
dash
11
Nov 17, 2004 11:40 PM
