What do you guys use for a EF9 Pin stripe! (searched)
Old May 23, 2006 | 01:55 PM
EHondaD6's Avatar
Default What do you guys use for a EF9 Pin stripe! (searched)
Do you guys know where i could find EF9 style pin stripes? or what size it is?
I have pin stripes but its too thin....
any ideas?
TIA
Old May 23, 2006 | 02:00 PM
RE- v8killa121's Avatar
Default Re: What do you guys use for a EF9 Pin stripe! (HondaED6)
I just put some on my hatch on sat., after i painted the moldings black..
i just went to autozone and bought the 1/4" 40' roll of red pin-stipe they had...
i came out all right, and left about 1/16" on each side of the stripe.
Old May 23, 2006 | 02:39 PM
EHondaD6's Avatar
Default Re: What do you guys use for a EF9 Pin stripe! (RE- v8killa121)
EDIT:
i think 1/4 is what i have right now....I believe its 1/2 inch to be exact..doe anyone know?
Old May 23, 2006 | 02:46 PM
I measured mine out at 3/8", so that 1/4" left just a lil' left over
Old May 23, 2006 | 03:48 PM
fourthgenhatchB17's Avatar
From what i can recall, i measured the gap to be around 7 or 8mm wide. I had a decal shop cut them in pre-determined lengths. Have fun applying them. **** is a bitch trying to get them as straight as possible!!
Old May 23, 2006 | 07:20 PM
EHondaD6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RE- v8killa121 &raquo;</TD></TR><TR><TD CLASS="quote">I measured mine out at 3/8", so that 1/4" left just a lil' left over</TD></TR></TABLE>
do you happen to have any pics of yours?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">From what i can recall, i measured the gap to be around 7 or 8mm wide. I had a decal shop cut them in pre-determined lengths. Have fun applying them. **** is a bitch trying to get them as straight as possible!!</TD></TR></TABLE>
i see, i didnt even think of this possibilty..thanks for the insight...
Old May 23, 2006 | 07:36 PM
kylefakesi-r's Avatar
peel the backing of at hte the end and apply it past where you are actually going to apply it. then you can unroll how much you need and pull it straight. once you have it laid accross hwere it is going to be hold the end away from the car and peel the backing paper off. you can then lay it down into the gap in the moulding extremely straight.
(picture sticking a piece of tape to the hubcap/wheel and then pulling it back accross the side of the car. then trim it. this way you always have clean application and edges)
3m vinyl. 3/8"
if i had pics i would post them...it's hard to describe
Old May 23, 2006 | 08:57 PM
Default Re: What do you guys use for a EF9 Pin stripe! (kylefakesi-r)
Heres the one i did. Its 3M stuff too. The door decals are replicas so i had them match it to the stripe in the same silver.
Kylesfakesir: I really would like to see detailed shots of yours. I remember when i went to the Eibach meet, there were like 10 guys there with the red stripe, and ALL of them were crooked as ***. It was so nasty looking...
Old May 23, 2006 | 09:59 PM
Nisif's Avatar
Default Re: What do you guys use for a EF9 Pin stripe! (fourthgenhatchB17)
Are you guys using the pin stripes on USDM side moldings or JDM? I'm unaware if there is even a difference between the two or not. I'd liked to do this to my hatch but it has usdm moldings on it.
Old May 23, 2006 | 10:11 PM
SiR Inspired ED7's Avatar
Well, here's my ride's
Not The best but it's there. I'm currently looking for all around jdm mouldings for my hatch, if ya know where i can get some let me know other than that on my door mouldings i have that red stripe from auto zone.
1988 Crx Si
1990 Civic Si Hatchback
Old May 24, 2006 | 03:04 PM
EHondaD6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kylefakesi-r &raquo;</TD></TR><TR><TD CLASS="quote">
3m vinyl. 3/8"
if i had pics i would post them...it's hard to describe</TD></TR></TABLE>
thats the ticket.. thanks..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Heres the one i did. Its 3M stuff too. The door decals are replicas so i had them match it to the stripe in the same silver.
your car is sick....more pics..
Old May 24, 2006 | 03:44 PM
temp's Avatar
Kylesfakesir: I really would like to see detailed shots of yours. I remember when i went to the Eibach meet, there were like 10 guys there with the red stripe, and ALL of them were crooked as ***. It was so nasty looking... </TD></TR></TABLE>
rear drums? eewwww
Old May 24, 2006 | 06:03 PM
The black hatch is NOT mine, its just my work on it. Heres another angle of the black one, even though its from afar, and my car (white hatch) in the same pic. As you can see, I dont run pin striping on mine.
Old May 24, 2006 | 06:20 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">The black hatch is NOT mine, its just my work on it. Heres another angle of the black one, even though its from afar, and my car (white hatch) in the same pic. As you can see, I dont run pin striping on mine.
hehehe
Old May 24, 2006 | 07:09 PM
this was on midwest hybrid/derric/gary's old real si-r
Old May 24, 2006 | 08:32 PM
ENJOI's Avatar
is this for 88-89 door mouldings?
Old May 24, 2006 | 08:34 PM
^^ It appears to be crooked in some spots. Im super **** about this kind of stuff. On a side note the real deal stuff is actually a red/orange (same color as the striping on the EF9 seats), not pure red like everyone has.
yes, this is for the 88-89 moldings.
Modified by fourthgenhatchB17 at 5:47 AM 5/25/2006
Old May 25, 2006 | 04:50 AM
temp's Avatar
whoa, kyle! its blackturtle916 from jdmcivic
Old May 25, 2006 | 07:14 AM
Default Re: What do you guys use for a EF9 Pin stripe! (temp)
what's up.
that's not my ef9. my rhd is black not barcelona green. that was another dude's real ef9 from the area that was restored.
as for the coloring...if you look at the real ef9...it is the red/orange.
Old May 25, 2006 | 07:27 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kylefakesi-r &raquo;</TD></TR><TR><TD CLASS="quote">what's up.
as for the coloring...if you look at the real ef9...it is the red/orange.</TD></TR></TABLE>
nada, moving to japan in september
Old May 25, 2006 | 09:07 AM
say what?!?!?!
guess who just got a shopping list from me for the little things on my car that need attention but aren't available on this side of earth...damn rhd cars and non-interchangeable parts.
Old May 25, 2006 | 09:10 AM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kylefakesi-r &raquo;</TD></TR><TR><TD CLASS="quote">say what?!?!?!
guess who just got a shopping list from me for the little things on my car that need attention but aren't available on this side of earth...damn rhd cars and non-interchangeable parts.</TD></TR></TABLE>
HEHEHEHEHE yessir, moving in september. once i get there and get all situated i will let you guys know, you arent the first person talking about a shopping list
Catch 22
48
Mar 19, 2006 07:24 AM
x_outlaw_x
Jan 8, 2006 01:05 PM
Race Egr
Welding / Fabrication
27
Aug 21, 2005 05:31 PM
AllMoToRB18c
Aug 18, 2005 06:31 AM
chitownrida
Honda Motorcycles
19
Apr 18, 2005 08:45 PM
