air/fuel gauge
Old May 23, 2006 | 01:39 PM
MniMeHatch89's Avatar
Default air/fuel gauge help...please
i just got a air/fuel gauge from a friend and its phantom autometer gauge. it has 3 wires purple red black. red-power, black-ground, and purple is O2 signal. if i hook up ground and power the light comes on then when i hook up the signal wire the light goes away and wont come on at all. i can rev or do whatever and the light wont show. anybody have any advice? much appreciated
Modified by MniMeHatch89 at 3:27 PM 5/23/2006
Old May 23, 2006 | 02:42 PM
Relic1's Avatar
which car are you putting it into? Which ECU and which O2 sensor?
are you sure you're connecting it to the right wire?
be warned they are just a light show. pretty much worthless unless there is a serious major problem.
Old May 23, 2006 | 04:03 PM
my 89 hatch with a d16z6 ....p28 ecu with a 4 wire O2 sensor. white wire is signal, 2 blacks are for heater, and green is ground.
Old May 24, 2006 | 09:45 AM
anyone that can help me?
Old May 24, 2006 | 10:59 AM
Relic1's Avatar
it sounds like you have everything connected right, do you have a volt meter to check what voltage is on the O2 signal wire? it should be 0-1 volt. if it's more then the gauge would do what you describe.
Old May 24, 2006 | 11:56 AM
alphaek's Avatar
Default Re: air/fuel gauge help...please (MniMeHatch89)
Old May 24, 2006 | 06:17 PM
antivic's Avatar
u hook it up to the right signal?
Old May 25, 2006 | 12:50 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: air/fuel gauge help...please (antivic)
You might as well sell it. Unless its hooked to a wideband O2 sensor, its pretty much useless.
Old May 25, 2006 | 01:25 PM
why is it useless
Old May 25, 2006 | 01:31 PM
devnull's Avatar
You have to drive around, The autometer gauges don't have a real good tolerance for running rich or lean. Also you have to let it heat up first. So drive the car around for 30 minutes and it will work. Also most of the time it will be no lights, last green (rich) or red (lean). It will only hit "stoich" when it's passing through from rich to lean of vise versa.
Also the Autometer air/fuelk is useless. It only shows you within one volt (narrowband) if you are rich or lean. Nothing in the middle and definitly what your mixture actually is. It's just a blingy type gauge no real data comes from it. Only goo air/fuel are AEM UEGO and plaxo units.
jarven93
Nov 18, 2009 06:01 AM
danno33
17
Aug 9, 2007 07:41 PM
JDMhondalude22
Oct 26, 2006 06:14 AM
GorData
Feb 18, 2002 10:27 PM
integra0260
Jul 28, 2001 03:35 PM
