Nology, Field SFC-Vtec, OEM, Skunk2 - San Diego
Old May 23, 2006 | 12:27 PM
Aloha04MSM's Avatar
Default Nology, Field SFC-Vtec, OEM, Skunk2 - San Diego
1 set of red Nology Hotwires used in good condition. Amazing spark plug wires. Noticeable difference in gas milage and power/engine response. These will fit any integra gsr or type r 94+ as well as any civic/crx 88+ with a 1.6L non-vtec engine (you can verify these applications on nology's website). - $100
1 used, in good condition Field SFC-Vtec controller. It enables you to change your Vtec crossover point up or down in 100 rpm intervals. It also enables you to modify your fuel curve in 1000 rpm intervals to better tune your engine. It also has a speed limiter removal feature, which is especially helpful if you are running an ecu with a speed governor (like a jdm honda ecu). Comes with full wiring harness (about 3 feet long) so you can put it anywhere you want in your car. - $125
1 Skunk2 Skunk 2 Battery Tie Down for a Honda or Acura running the small honda-sized battery. It is Brand new in the box. - $35
1 set of stock springs from my 96 gsr. They came off the car at 65k miles. I am asking for 20 bucks picked up.
Old May 23, 2006 | 05:09 PM
Aloha04MSM's Avatar
bump
Old May 24, 2006 | 06:54 AM
Aloha04MSM's Avatar
Default Re: Nology, Field SFC-Vtec, OEM, Skunk2 - San Diego (b18cinteg96)
bump
Old May 24, 2006 | 05:20 PM
Aloha04MSM's Avatar
Old May 25, 2006 | 12:48 PM
Aloha04MSM's Avatar
Old May 26, 2006 | 02:02 PM
Aloha04MSM's Avatar
bump
darklyte
Northern California (Sales)
19
Jul 30, 2007 11:42 AM
Aloha04MSM
May 26, 2006 02:03 PM
Stop the Beast
Mar 4, 2002 09:05 PM
Kalokohan
Apr 26, 2001 07:10 AM
