Nology, Field SFC-Vtec, OEM, Skunk2
1 set of red Nology Hotwires used in good condition. Amazing spark plug wires. Noticeable difference in gas milage and power/engine response. These will fit any integra gsr or type r 94+ as well as any civic/crx 88+ with a 1.6L non-vtec engine (you can verify these applications on nology's website). - $100
1 used, in good condition Field SFC-Vtec controller. It enables you to change your Vtec crossover point up or down in 100 rpm intervals. It also enables you to modify your fuel curve in 1000 rpm intervals to better tune your engine. It also has a speed limiter removal feature, which is especially helpful if you are running an ecu with a speed governor (like a jdm honda ecu). Comes with full wiring harness (about 3 feet long) so you can put it anywhere you want in your car. - $125
1 Skunk2 Skunk 2 Battery Tie Down for a Honda or Acura running the small honda-sized battery. It is Brand new in the box. - $35
1 set of stock springs from my 96 gsr. They came off the car at 65k miles. I am asking for 20 bucks picked up.
Aloha04MSM
May 26, 2006 02:02 PM
sys3rror
Dec 3, 2003 11:06 AM
