Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
2003 Acura CL Type S - left sunroof open
Old May 23, 2006 | 10:23 AM
Trixy's Avatar
Default 2003 Acura CL Type S - left sunroof open
I left my sunroof open last night and it rained pretty hard. I dried the seats off and used some armoral leather to try and repair any damage that might have happened to the seats but the other thing that happened was my SRS light came on and stayed on. I know that's something to do with the airbag but could this be caused by water getting in somewhere???
Modified by Trixy at 2:07 PM 5/23/2006
Old May 23, 2006 | 02:17 PM
Kenso's Avatar
HT White Ops
Default Re: 2003 Acura CL Type S - left sunroof open (Trixy)
The occupant position detection sensor (OPDS) in the pass. side seatback probably got wet, which would cause the SRS light to come in most cases. The OPDS components are very sensitive, getting them wet would definitely cause problems. If you wait until it dries out completely, then take it to the dealership, you should be able to get it fixed under warranty if that's the problem. The OPDS system has a lot of problems in general and Honda extended the warranty on it to 150k miles here in the US, not sure about Canada. If they don't know that it ever got wet, they should replace it no questions asked pretty much.
Could be other issues as well, depending on just how wet the interior got, but the OPDS system is the most vulnerable.
Old May 23, 2006 | 02:26 PM
Trixy's Avatar
Default Re: 2003 Acura CL Type S - left sunroof open (Kenso)
Thanks Kenso. That's probably exactly what happened. The seats are pretty dry now. I let it sit in the sun for a while today and left the windows open to air it out. I have an appointment to take it in next Monday, so that's a week away. Do you think it will be completely dry by then, so that they don't know it was my own stupidity that caused it?
Old May 23, 2006 | 04:51 PM
Kenso's Avatar
HT White Ops
Yeah, it should have dried out pretty well by then. Good luck with things.
sudorc
Honda Civic (2001 - 2005)
14
Apr 17, 2024 06:32 AM
NA4sho
Honda Civic (2006 - 2015)
Feb 2, 2007 06:01 AM
seer
Sep 12, 2006 03:42 PM
pcorad
13
Mar 9, 2004 07:30 AM
