Map sensor removal...
Old May 23, 2006 | 05:46 AM
'90crxSI's Avatar
Default Map sensor removal...
Has anyone had to replace there map sensor? If so, was it 'riveted' to the throttle body? How did you remove it? And, I'm assuming that instead of re-riveting or whatever, you used screws to reattach it?
Old May 23, 2006 | 06:53 AM
crx_88_si's Avatar
thats not the map sensor.
you are talking about the TPS sensor. To get the TPS sensor off you need to cut slits in the rivits like a flat head screw.
WalkerGSR1
Oct 27, 2006 02:01 AM
88 rex
Aug 4, 2005 04:58 PM
aznballerz
Jun 12, 2004 12:38 PM
comptechgsr2000
May 8, 2002 03:53 PM
