Brake Cooling Ducts?
Old Apr 12, 2002 | 04:51 PM
nsxtcjr's Avatar
New User
Default Brake Cooling Ducts?
Has anyone here tried installing cooling ducts to your brakes on your ITR? If so, did you cut various body parts to do so? What size? Where did you run it? Photos would be particularly helpful.
Yes, I tried doing a "search", but you know how well that works...
Old Apr 12, 2002 | 05:10 PM
Dr Pooface's Avatar
Default Re: Brake Cooling Ducts? (nsxtcjr)
There is some info here, under mods: http://www.sandmracing.com/
Old Apr 12, 2002 | 05:18 PM
nsxtcjr's Avatar
New User
Default Re: Brake Cooling Ducts? (Ddub)
Thanks. Looks good.
Is it a straight shot past the radiator going back, or did you have to cut metal above the core support as well?
Old Apr 12, 2002 | 05:44 PM
yoshi234's Avatar
I shoot brides
I should have pix of my 'cure' for c00ler brakes
Old Apr 12, 2002 | 05:50 PM
Dr Pooface's Avatar
Thanks. Looks good.
IM D for info, as those are his pics.
Old Apr 12, 2002 | 05:57 PM
D's Avatar
D
just a FYI, havn't had this on the track yet, as i am again a poor poor college student in need of rotors, pads and money for events (hint hint).... but i'm confident this should solve much of the brake heating with our front stoppies.
D
Old Apr 12, 2002 | 06:22 PM
Chris's Avatar
Default Re: Brake Cooling Ducts? (D)
Old Apr 12, 2002 | 10:07 PM
nfn15037's Avatar
Ds look nice, ive seen em on his car around. Looks like it should have been there from the factory.
Old Apr 13, 2002 | 12:54 AM
Art Vandeleigh's Avatar
Default Re: Brake Cooling Ducts? (Chris)
how is that working for you?? i might try that but i have the ice box in the pass corner....but that looks really promising....
Old Apr 13, 2002 | 05:18 AM
Dropspeed's Avatar
I am in the middle of installing mine, Sorry no pics. But I have two NACA ducts in the opening of the fascia were the factory fog lamps would fit. Because I removed the a/c there is room to run the hose/ducting stright back in between the radiator and the core support, then running along the z-10 radius rods towards the front brakes. Hopefully I'll have something finished before the Expo.
Mattj
[Modified by Dropspeed, 9:40 AM 4/14/2002]
Old Apr 13, 2002 | 08:05 AM
Big Phat R's Avatar
Default Re: Brake Cooling Ducts? (Dropspeed)
NACA not NASA
Old Apr 13, 2002 | 09:42 PM
Renegade's Avatar
Has anyone built a more permanent system than the flimsy tubing?
Not trying to flame on everyones set up, just curious...
Old Apr 13, 2002 | 10:40 PM
nfn15037's Avatar
Default Re: Brake Cooling Ducts? (98401R)
Im not sure you would really want to. Most race cars(excluding CART, F1 etc) use flexible hose like the stuff shown in most of the pix. I guess if you were really ambitious, you could make some nice CF ducts, but that would be a pain in the *** for not really any gains. Just my $.02
[Modified by nfn15037, 11:41 PM 4/13/2002]
Old Apr 13, 2002 | 11:06 PM
GokuSSJ4's Avatar
Default Re: Brake Cooling Ducts? (VTEC CX)
Old Apr 14, 2002 | 05:41 AM
Dropspeed's Avatar
Default Re: Brake Cooling Ducts? (Phat Bastard)
NACA not NASA
Its top secret prototype NASA ducting............OK I ment NACA.
Mattj
Old Apr 14, 2002 | 06:11 AM
nsxtcjr's Avatar
New User
It's not rocket science.
Old Apr 14, 2002 | 09:01 AM
Renegade's Avatar
Default Re: Brake Cooling Ducts? (nfn15037)
I was thinking along the lines of Aluminum ducts that can be mounted with a few screws.
I don't know about CF that's alot harder to do, but would look cool.
Old Apr 14, 2002 | 09:53 AM
nfn15037's Avatar
Yeah, get some sheet aluminum and a pop-riviter and go to town. It would definately be much sturdier.
no1else
Honda CR-V & Element
Jun 23, 2013 03:32 PM
blulude92
May 22, 2006 08:07 AM
nsx-Animal
Sep 3, 2002 09:00 PM
mikeSONICGSR
Dec 10, 2001 03:12 PM
Reverend
Aug 30, 2001 08:16 AM
