del sol shift linkage PLEASE HELP!!!!
Old May 22, 2006 | 06:27 PM
delsoldrew's Avatar
Default del sol shift linkage PLEASE HELP!!!!
i have a 93 del sol si and i swapped the tranny off and put in a y8. my dad threw away my old tranny before i found this out. the y8 shift linkage is about 3-4 inches too short. will a shift linkage off a z6 from a civic work? or do i need one from a d16z6 del sol ?
Old May 22, 2006 | 06:35 PM
skip.two's Avatar
Default Re: del sol shift linkage PLEASE HELP!!!! (delsoldrew)
you will need either the Z6 or Y8 shiftlinkage from a Del Sol.
Old May 22, 2006 | 06:54 PM
Syndacate's Avatar
ya, has to be from a D16 delsol, can't take one from a reg civic
Old May 22, 2006 | 07:25 PM
Out of every
Default Re: del sol shift linkage PLEASE HELP!!!! (skip.two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skip.two &raquo;</TD></TR><TR><TD CLASS="quote">you will need either the Z6 or Y8 shiftlinkage from a Del Sol.</TD></TR></TABLE>
very true.. im not following you skip. we just share the same brain
Old May 22, 2006 | 07:28 PM
skip.two's Avatar
Default Re: del sol shift linkage PLEASE HELP!!!! (e gee two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e gee two &raquo;</TD></TR><TR><TD CLASS="quote">very true.. im not following you skip. we just share the same brain </TD></TR></TABLE>
stalker.
Old May 22, 2006 | 09:23 PM
rs-r's Avatar
WHY DON'T YOU JUST GO TO THE NEAREST PICK-AND PULL OR DISMANTLER CIVIC PLACE WITH YOUR SHIFT LINKAGE TO SEE IF THEY COULD LET YOU COMPARE FOR WHAT YOU NEED.
Old May 22, 2006 | 09:26 PM
skip.two's Avatar
Default Re: (rs-r)
why don't you stop yelling and turned the capslock off.
there's nothing to compare. he needs a D-series shiftlinkage from a 93-97 Del Sol.
Old May 23, 2006 | 12:04 PM
delsoldrew's Avatar
THANX!!!!!!!
yellowmonkeyboy
Jun 25, 2007 05:39 AM
Arsenal
Nov 3, 2005 04:35 AM
jd_bh03
Jul 14, 2004 02:15 PM
sk8rmike
35
Oct 20, 2003 06:35 AM
