what offset and tire size do you guys recommend
Old Apr 12, 2002 | 03:57 PM
Double 06's Avatar
New User
Default what offset and tire size do you guys recommend
I'm going with 16's but i don't know if i should be +40 or +45, stock 15's are+50.
what size tires do you recommend, and types? Need something that will last a while, but at the same time have great performance. you input is important ,, thanks.....
Old Apr 12, 2002 | 04:22 PM
Cosworth's Avatar
Default Re: what offset and tire size do you guys recommend (Double 06)
I would go with 16x7" 50mm or 45mm offset. JDM factory wheel size if 16x7" w/ 50mm offset I believe. 45mm offset is as low as I would go... but there's really no need for anything lower then 45mm (unless you're serious track racer who want wider track for your ITR).
(there are 35mm offset in 16x7" rims... but seems like an overkill for normal street/autoX driving)
Tyte-S
Aug 20, 2009 09:38 PM
94 IntegraLS
May 18, 2007 03:26 PM
TrueZen
Apr 24, 2003 05:38 PM
CoolKat
Jan 23, 2003 08:58 PM
Batoutahell
20
Dec 22, 2002 07:58 AM
