Tranny Fluid
Old May 22, 2006 | 06:15 PM
roterx7's Avatar
Default Tranny Fluid
how many quarts of oil do i need and how do i get the new oil in the tranny?
thanks
89 crx with sohc zc (not sure which d. tranny i have)
Old May 22, 2006 | 06:30 PM
zccr-xsi's Avatar
3 quarts.
and u can fill it by unscrewing the back-up swicth on the top of the tranny.
Old May 22, 2006 | 06:38 PM
roterx7's Avatar
so 3 quarts? man some one told me 2 quarts. also im leaking a little bit of tranny fluid and it not from the drain plug. any other place it can leak from?
thanks
Old May 22, 2006 | 06:51 PM
downest's Avatar
Default Re: (roterx7)
To change the tranny fluid, you need a 17mm and a 3/8" drive ratchet. Get under the car on the passenger's side and you will see a bolt with a square cut out, it has a longer head than the other bolts. Your 3/8" ratchet will fit right in there, loosen it to drain the fluid. Behind and above it is the fill hole, you might want to open that first to make the draining quicker and smoother. Once it's drained, put the drain bolt back in. Now use a funnel with a tube (I use fuel hose) and get it in the fill hole, holding the funnel at the top of the tranny where you can get to it. Now just start filling it up, until it dribbles out the fill hole. Make sure the car is level while you fill it. It's kind of a pain to do, it takes a while for the oil to go through the tube. You can also use other holes on the tranny to fill it, as long as you leave that hole open so you know when it's done, personally I always use the fill hole. Use either Honda MTF or 10W40. I use motor oil because that's what the manual says, and with the number of times I've had to drain the damn tranny I would be even more broke using Honda MTF.
Old May 22, 2006 | 07:05 PM
zccr-xsi's Avatar
if axles arent sealed it will leak from there!
i use pennzoil syncomesh
Modified by vteckillenzc at 8:47 PM 5/22/2006
Old May 22, 2006 | 07:28 PM
M15's Avatar
M15
Default Re: (vteckillenzc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">if axles are sealed it will leak from there!
i use pennzoil syncomesh </TD></TR></TABLE>
For syncromesh, greatest stuff ever made.
Old May 22, 2006 | 07:29 PM
zccr-xsi's Avatar
only 6.66 at autozone
10$ at the gm dealer and its the same ****
DC_RaceR's Avatar
Default Re: (M15)
almost 2 quart on mine
Old May 22, 2006 | 10:46 PM
88CRsXy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">if axles arent sealed it will leak from there!
im assuming what u mean by not sealed is the little oil seal that's attached to the tranny when u pull off the axles. it looks like an o-ring with a spring around the circumference (sp)
Old May 22, 2006 | 10:50 PM
roterx7's Avatar
so 2 quarts? or 3 quarts? i want to know to see if i have to go buy another quart before i do it.
thanks
Old May 22, 2006 | 11:02 PM
88CRsXy's Avatar
buy 3 just in case. better to have more than not enough.
Old May 23, 2006 | 04:27 AM
njcrxsi's Avatar
Default Re: (88CRsXy)
u peepal r crazy..d-tranny only take 1.8 qt..if ful flush it iz 1.9 or 2 qt..
Old May 23, 2006 | 07:47 AM
Gearspeed-Performance's Avatar
Default Re: (brijpurt13b)
1.9 qts....Wouldn't hurt to buy three and have a quart on the shelf...but, don't overfill the transmission. 1.9
Old May 23, 2006 | 08:24 AM
ludesrv's Avatar
I always, always do a run thru on a tranny fluid swap. It's a good idea to clean up the bottom of the casing. Simply run thru some 10w30 to pick up any old crap laying at the bottom. Then simply start filling her up until the check plug starts leaking out, making sure the car is level, let the fluid level off at the check plug (that's the 17mm plug). Simply add until you are certain it's levelled off and not low. Then plug it up and seal her up. I've done personally (since I worked at a lube shop) 200 manual transmission flush, it's always what I've done, and I've never had a problem. The stock D series in cable take 10w30 out of factory. You can upgrade to Honda Manual or Syncromesh if you feel the tranny is worn out.
Old May 23, 2006 | 12:08 PM
zccr-xsi's Avatar
yes make sure the axle housing sit flush wit the tranny housing.mine leaked untill i pushed it in all the way.
Old May 23, 2006 | 12:26 PM
FOMULA91's Avatar
1.8-2 qts because I force 3 qts before and it started to leak from the seal.
Old May 23, 2006 | 12:50 PM
ludesrv's Avatar
Stick in all you want, aslong as the check plug is off it will self level to 2 qts if the car is level.
Old May 23, 2006 | 06:21 PM
roterx7's Avatar
alright koo so its settle 2 quarts. i was also wondering where else can fluid leak from insted of the drain plug. the seal? and if it is that would i have to take off the whole tranny to replace that?
thanks
Old May 23, 2006 | 07:32 PM
FOMULA91's Avatar
Mine was leaking from the axel seal and the actual seal from the transmission cuz my bro opened it and didn’t use the right gasket. But some people say that it also leak from the shift linkage.
Old May 24, 2006 | 12:22 PM
roterx7's Avatar
i seen the oil from my driver side axle, of couse where the axle goes into the tranny. kinda greasy around there. but yea so i need to push it in more or buy a new gasket it or something. ether way i would have to go thru the step like im changing my axle?
Modified by roterx7 at 1:34 PM 5/24/2006
Old May 25, 2006 | 08:22 AM
FOMULA91's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roterx7 &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by roterx7 at 1:34 PM 5/24/2006</TD></TR></TABLE>
YES
Old May 25, 2006 | 03:28 PM
roterx7's Avatar
alright at least i know what i have to do now. what is the correct name for that gasket?
Old May 25, 2006 | 05:23 PM
zccr-xsi's Avatar
Default Re: (FOMULA91)
yea i force 3 quarts too and it leaks till it to level.
Old May 28, 2006 | 11:00 AM
roterx7's Avatar
i cant figure out the name for the gasket i need. can some one help me out?
thanks
Old May 28, 2006 | 11:08 AM
nappyroots827's Avatar
ok, just so you don't mess anything up, first of all the manual says it takes 2.7 quarts, which is what mine took when i last filled it, and if your not sure what tranny you have, just fill it until it leaks out the fill hole, the fluid level is supposed to be at the exact height of the fill hole, so you don't need to worry about doing it wrong, and just buy 3 quarts, because i garuntee ure gonna need more than 2, you may even wanna buy a 4th, cuz if u haven't done it in a while, i always like to buy a **** quart of oil and run it through to get the old stuff out
