what injectors are these?
Old May 22, 2006 | 06:08 PM
iHOPEyouCHOKE's Avatar
* B A N N E D *
Default what injectors are these?
hihi, these were given to me by a friend.. we don't know what they are, we've heard they are 310cc buick injectors, but was hoping one of you guys could tell us what they truely are. the only thing written on them are "D193 17113798"
PIC:
Old May 22, 2006 | 06:11 PM
macDelli's Avatar
Default Re: what injectors are these? (iHOPEyouCHOKE)
hmm
Old May 22, 2006 | 06:12 PM
* B A N N E D *
Default Re: what injectors are these? (macDelli)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by macDelli &raquo;</TD></TR><TR><TD CLASS="quote">hmm</TD></TR></TABLE>
hmm
Old May 22, 2006 | 06:14 PM
chilly.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by macDelli &raquo;</TD></TR><TR><TD CLASS="quote">hmm</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iHOPEyouCHOKE &raquo;</TD></TR><TR><TD CLASS="quote">
hmm
Old May 22, 2006 | 06:16 PM
s2kdre's Avatar
Default Re: what injectors are these? (chilly.)
look like precisions
Old May 22, 2006 | 06:17 PM
* B A N N E D *
Default Re: what injectors are these? (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">look like precisions</TD></TR></TABLE>
gad damn i'd hope so
CO_CReX's Avatar
Ya they look precisions
Old May 22, 2006 | 06:21 PM
* B A N N E D *
Default Re: (CO_CReX)
well hot damn
any way to tell what cc they are?
Old May 22, 2006 | 06:29 PM
* B A N N E D *
Default Re: (iHOPEyouCHOKE)
can someone tell me if they'll fit a d16z6?? i have no idea 1) what they are 2) what cc or if their obdwhowhat.
Old May 22, 2006 | 06:31 PM
shynop
Guest
Posts: n/a
they look like...yup they are fuel injectors
s2kdre's Avatar
they have obd1 clips but precisions dont have cc numbers on them and they will fit any honda rail
Old May 22, 2006 | 06:33 PM
* B A N N E D *
Default Re: (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shynop &raquo;</TD></TR><TR><TD CLASS="quote">they look like...yup they are fuel injectors </TD></TR></TABLE>
kaythanxbye.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">they have obd1 clips but precisions dont have cc numbers on them and they will fit any honda rail</TD></TR></TABLE>
so these will infact fit a d16z6?
Old May 23, 2006 | 01:32 PM
CO_CReX's Avatar
so these will infact fit a d16z6? </TD></TR></TABLE>
Yes they should.
Old May 23, 2006 | 01:42 PM
xtrac1's Avatar
rookn00b
Thats a Rochester brand injector. Its high impedance (12-16ohms) and flows about 370-390cc/min. The top is machined for a Honda/Denso application. The bottom is standard Bosch, if you play around with different seals, you should get it to fit Honda applications.
Old May 24, 2006 | 05:22 AM
* B A N N E D *
Default Re: what injectors are these? (xtrac1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtrac1 &raquo;</TD></TR><TR><TD CLASS="quote"> Thats a Rochester brand injector. Its high impedance (12-16ohms) and flows about 370-390cc/min. The top is machined for a Honda/Denso application. The bottom is standard Bosch, if you play around with different seals, you should get it to fit Honda applications.</TD></TR></TABLE>
wow thanks.
so would these injectors be ideal for a single cam turbo setup?
Old May 24, 2006 | 05:59 AM
Phil DeVtec's Avatar
nice!
Old May 24, 2006 | 09:20 AM
xtrac1's Avatar
rookn00b
wow thanks.
so would these injectors be ideal for a single cam turbo setup?</TD></TR></TABLE>
They should be able to support about 260HP +/- 20HP. Keep in mind that these are large enough that the factory ECU won't be able to handle them (idle quality/off boost drivability). You will need basic control of the injectors with an Apexi VAFC or something better.
Old May 24, 2006 | 02:11 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtrac1 &raquo;</TD></TR><TR><TD CLASS="quote">They should be able to support about 260HP +/- 20HP. Keep in mind that these are large enough that the factory ECU won't be able to handle them (idle quality/off boost drivability). You will need basic control of the injectors with an Apexi VAFC or something better. </TD></TR></TABLE>
you know your ****
i'm planning on getting it tuned by John Kerr (j-ktuning), when we tune we're going to throw the injectors in. hopefully these will be good for my setup
thanks.
mike
yee SERIOUS
Feb 18, 2008 07:25 AM
aero97
Dec 16, 2006 04:20 AM
all_out_jdm
Oct 17, 2005 09:35 PM
ihavemoles
Honda S2000
Jun 1, 2005 04:14 PM
EGsixer
Jan 14, 2004 10:12 PM
