b20 vtec?
i would use a B16 head and your redline depends on your ECU. stock bottom end should hold up to 8.5K but your valve trans wont hold that high of a rev, im not sure how much the valve trans could go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 530guy »</TD></TR><TR><TD CLASS="quote">ok i just wanted to know what would be the easiest way to make my b20 vtec, could i just use a vtec head with a golden eagle kit? if so what would be the redline?</TD></TR></TABLE>
7200 RPM unless you want to spin rod bearings. You're going to need ARP rod bolts if you want to reliably rev any higher.
