tps sensor
Not to hard to do, easy when the TB is out of the car but still possible in, easiest is to get a dremel and just cut a line in the head of the screw....they are rivit topped but have threads so make the rivit into a flat head and just use a screw driver
or you may just have to drill off the head, use a large drill bit and drill of the larg head and then use a vice grip to thread the screw out...now that you have them out replace them with some screws with hex/socket head incase you ever have to remove it again...also make sure that the little arm in the sensor is on the throttle arm in there or you will get a code...you'll see what I mean when you have it off, HTH
Luserkid
Dec 9, 2004 02:24 PM
