93 prelude si~~~~NEED HELP!!
Its a 93 prelude with an H23. Like a month ago it started fine, and i noticed that it was taking longer for the car to start up during any time of the day. Then i didnt drive the car for a month and when i go start the car it starts up fine but then shuts down very quick. Now when i try to start it, it cranks but doesnt start. Changed the spark plugs and batter....what could be the problem?
not knowing mileage, what else has been done hard to say. I would say fuel filter, fuel pump, injectors, fuel pressure regulator. Heck, just run some injector cleaner through your next tank of gas and see what happens.
K
K
check the ecu ..... try plugging up another p14 ecu up and see if it will start up , i had a similar problem you had .... swapped ecus and my car ran fine ....
zsudz922
Jan 9, 2008 07:49 AM
