Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Front mount intercoolers, does weight cause understeer?
Old Apr 12, 2002 | 03:25 PM
flybert's Avatar
Default Front mount intercoolers, does weight cause understeer?
Does a turbo system with a large fmic cause noticeable understeer? Just curious.
Old Apr 12, 2002 | 05:14 PM
Catch 22's Avatar
Default Re: Front mount intercoolers, does weight cause understeer? (flybert)
Don't know, never driven one.
But in general, adding weight to the front of a FWD car which is already very front heavy is a bad thing. Especially if the weight is wayyy up front and forward of the wheels.
You can always counter this by removing or relocating weight. Removing the air conditioner and power steering pump, and relocating the battery to the rear will help alot.
If you run in competition, make sure this stuff is legal.
Old Apr 12, 2002 | 06:12 PM
.RJ's Avatar
.RJ
Diving too fast into a corner causes understeer. No matter what you drive, even if its a miata. I can make my nose-heavy soft sprung saturn not understeer. Its all about being smooth.
RJ
Old Apr 12, 2002 | 06:16 PM
tegtyper's Avatar
The WEIGHT? Hardly, what is it, an extra 30lbs??
Now, the extra power (assuming you have it tuned right) and if you mash the throttle on corner entry, Yes.
Old Apr 12, 2002 | 06:42 PM
Aahj's Avatar
Default Re: Front mount intercoolers, does weight cause understeer? (tegtyper)
it doesn't affect handling at all. It's a lot less than 30 pounds though.
this is mine: it's a tad big for my application.
good luck,
aj
Old Apr 13, 2002 | 11:32 AM
Mr. Vapor's Avatar
Default Re: Front mount intercoolers, does weight cause understeer? (ajn)
i have the DRAG intercooler on mine (spearco Core)
it doesnt wiegh anymore then 15lbs. its not a big deal. you figure the wieght you save by the damn stock exhaust manifold equals out in the end.
Old Apr 13, 2002 | 12:29 PM
jsi's Avatar
jsi
aj
Now here's an understatement. Did that IC came of a Cummins Turbo Diesel or something? Wow...
n-c
Oct 18, 2005 08:30 AM
LX4CYL
Mar 28, 2004 09:20 AM
scorched0
Jan 8, 2004 03:48 AM
allmotorhonda
Jan 2, 2003 04:55 PM
satan_srv
12
Dec 2, 2002 10:11 PM
