can i swap my stock 88 si 1.6 into an 84 rex?
I'm picking up an 84 rex and wanted to know that when i swap out the 88's motor (I'm guessing it's the a6? i'm not suire on the engine codes yet still new at this) would i be able to toss it in the 84? If so what will needed to be done. Or if anyone knows of a link i could check out thanks.
-lM-
-lM-
Yes the 88 Si should be the A6 engine if it's stock. There is a stamp on the front of the block.
As to swapping into your 84 CRX (carburated), it will be a difficult swap. You have to swap to fuel injected. You can find a lot for helpful info on this very subject at redpepperracing.com. Good luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt »</TD></TR><TR><TD CLASS="quote">You also MUST use a 1986-1989 Integra transmission.</TD></TR></TABLE>
hey man check ur pm
hey man check ur pm
EF_generation
Sep 9, 2004 05:18 PM
audioroach
May 13, 2003 04:04 PM
