Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
5mm Spacer, for those that have used spacers...
Old May 22, 2006 | 10:51 AM
Jon V's Avatar
Default 5mm Spacer, for those that have used spacers...
I'm looking at getting a set of 5mm spacers to clear my new brakes on my EK.
I need them so i can get my 16" +44 offset K1 wheels to clear my new TL 4 piston brakes, and I think the 5mm should do the trick.
My question is, what is the difference between the H&R spacers that sell for $50-$60 for a set of 2 and the genaric E-bay models that sell for $25 shipped?
Is there any centering or anything here to think about?
Old May 22, 2006 | 11:31 AM
Back in Black's Avatar
Rather OG
Default Re: 5mm Spacer, for those that have used spacers... (Jon V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V &raquo;</TD></TR><TR><TD CLASS="quote">Is there any centering or anything here to think about?</TD></TR></TABLE>
Yes. The H&R units are MUCH better quality and center themselves on the hub. I run them for this reason
Old May 22, 2006 | 12:51 PM
Jon V's Avatar
Default Re: 5mm Spacer, for those that have used spacers... (Back in Black)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Back in Black &raquo;</TD></TR><TR><TD CLASS="quote">
Yes. The H&R units are MUCH better quality and center themselves on the hub. I run them for this reason </TD></TR></TABLE>
thats what I figured...
Old May 23, 2006 | 10:42 AM
Jon V's Avatar
any sponcers sell H&R stuff?
Old May 23, 2006 | 01:28 PM
rsca_crx's Avatar
after breaking a couple sets of cheaper ones, i now run the h&r's with no issues. note that the cheap ones broke while running diamond steelie 13x8's, which are not hub-centric and contact the hub face (well, the spacer) on a fairly small area. ymmv.
Old May 24, 2006 | 05:02 AM
Jon V's Avatar
Default Re: 5mm Spacer, for those that have used spacers... (rsca_crx)
where did you get them? I can't seem to find anyone that stocks or can even order these for me...
Old May 24, 2006 | 05:15 AM
Rather OG
I got mine from King Motorsports.
http://www.kingmotorsports.com
Old May 24, 2006 | 05:43 AM
rsca_crx's Avatar
it was a while ago, but i'm pretty sure i got them at shox.com for a pretty good price.
Old May 24, 2006 | 10:04 AM
92acclude's Avatar
optauto.com has them
Old Mar 15, 2007 | 11:33 AM
Jon V's Avatar
Default Re: 5mm Spacer, for those that have used spacers... (92acclude)
well 5mm wasn't enough, looking for 15mm now since the 10mm weren't enough eigther... together the 10's and 5's work pretty well...
any advice/comments/concerns?
whats with the double stud ****?
Old Mar 15, 2007 | 01:25 PM
WWDTrackRacer's Avatar
New User
Default 15 mm spacer
I got a thick 15mm made from here: http://www.wheeladapter.com/wh...s.asp
Didn't go with integrated stud setup -- so this means you need long wheel studs.
H&R stuff is better made (coating, weight, machine quality (no sharp edges))
You can also try http://crowautomotive.com/bpage.html
I've been to both of these places btw, but only direct experience w/ the former.
Took about 1-2 weeks to get them made.
Old Mar 15, 2007 | 01:52 PM
Jon V's Avatar
Default Re: 15 mm spacer (WWDTrackRacer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WWDTrackRacer &raquo;</TD></TR><TR><TD CLASS="quote">I got a thick 15mm made from here: http://www.wheeladapter.com/wh...s.asp
Took about 1-2 weeks to get them made.</TD></TR></TABLE>
how much did they charge you? I already have my extended studs installed which is one reason I'm trying to avoid the integrated stud setup...
thanks
Old Mar 15, 2007 | 02:00 PM
New User
Default i forgot
i think it was around $75.
Old Mar 15, 2007 | 02:34 PM
STN_Pat's Avatar
Default Re: i forgot (WWDTrackRacer)
i use 3mm really cheap ones and no problem after 2 years
Old Mar 16, 2007 | 08:32 AM
nonsense's Avatar
Default Re: i forgot (STN_Pat)
These guys make some really nice spacers. Only up to 10mm so it's not going to help you much tho
http://onetongarage.com/produc....html
Old Mar 16, 2007 | 12:53 PM
Jon V's Avatar
Default Re: i forgot (nonsense)
Thanks guys...
probly going to get a set of hub-centric e-bay ones...
Old Mar 16, 2007 | 03:51 PM
mlrmotorsports's Avatar
Default Re: i forgot (Jon V)
turner motorsports carries all the H7R stuff if upu need to buy them still
Old Mar 17, 2007 | 11:07 AM
Jon V's Avatar
Default Re: i forgot (mlrmotorsports)
you got a link?
Old Mar 20, 2007 | 07:39 AM
Jon V's Avatar
anybody else make a 15mm 5x114.3 spacer with the non-integrated studs?
Old Mar 20, 2007 | 08:07 AM
Racerboy03's Avatar
H&R Hubcentrics, with non-integrated studs. With this big of a spacer, go with something high-quality and hubcentric:
http://www.kingmotorsports.com...at=14
Old Mar 20, 2007 | 09:31 AM
Jon V's Avatar
Default Re: 5mm Spacer, for those that have used spacers... (Racerboy03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racerboy03 &raquo;</TD></TR><TR><TD CLASS="quote">
Thats what I have been looking at so far...
I also found these on E-bay but I may just cough up the extra $20 and get the H&R's... http://cgi.ebay.com/ebaymotors...ZWDVW
BLUE EH3
13
Jan 16, 2007 05:29 PM
TRBODC2
Jan 13, 2007 05:26 PM
G2_Fella
Aug 27, 2006 01:54 PM
JamesV
Northern California (Sales)
13
Jun 29, 2006 10:06 AM
DUFFM4N
Aug 30, 2005 03:18 PM
