the d 4 on my 93 accord is flashing on my drive indicator
Old May 22, 2006 | 10:29 AM
scrappydog's Avatar
Default the d 4 on my 93 accord is flashing on my drive indicator
car doesn`t shift correctly and starts hard ,or not at all help !!!! thanks
Old May 22, 2006 | 11:02 AM
Ross 2.0's Avatar
In a Junkyard near you.
did you try to search???? I know this has been covered several times in the past month
Old May 22, 2006 | 07:43 PM
scrappydog's Avatar
Default Re: (MooGoCow3)
most talk about the light going on then off , mine stays on ,the car shifts wrong sometimes won`t start won`t down shift
Old May 22, 2006 | 07:45 PM
YeuEmMaiMai's Avatar
Default Re: (scrappydog)
if the light stays on it usually indicates that the TCU has failed. Doa search on that and you will find a crap load of threads on it.
Old May 23, 2006 | 08:14 AM
JimBlake's Avatar
Default Re: (YeuEmMaiMai)
It's just like the check-engine light, but for the tranny. Read codes just like reading CEL codes. Jumper the same wire, but the D4 light will flash instead (or along with) the CEL.
fonkernuckle
Mar 21, 2008 03:27 PM
primemal
Aug 7, 2006 09:09 AM
BlazeTeck2000
Jan 6, 2005 11:58 AM
Sia
Oct 18, 2004 10:20 AM
02AccordCoupe
Audio / Security / Video
May 2, 2003 06:56 PM
