Is the true or not!!!!
Old May 22, 2006 | 10:17 AM
Bseries!EF!hatch's Avatar
Default Is the true or not!!!!
I have a 1991 honda civic SI hatchback i am doing a ls motor swap i was told that the stock wireing harness out of my ef will plug up to my computer out of my 1992 da integra is this true!!
Old May 22, 2006 | 10:31 AM
1C9R9X1's Avatar
Default Re: Is the true or not!!!! (Bseries!EF!hatch)
i dunno, but my english teacher used to tell me "the answer that has 'never' or 'always' is usualy wrong".
Old May 22, 2006 | 10:36 AM
Autoworks's Avatar
Default Re: Is the true or not!!!! (1C9R9X1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1C9R9X1 &raquo;</TD></TR><TR><TD CLASS="quote">i dunno, but my english teacher used to tell me "the answer that has 'never' or 'always' is usualy wrong".</TD></TR></TABLE>
That is usually true
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bseries!EF!hatch &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1991 honda civic SI hatchback i am doing a ls motor swap i was told that the stock wireing harness out of my ef will plug up to my computer out of my 1992 da integra is this true!!</TD></TR></TABLE>
That is always false
An OBD0 harness will not plug into an OBD1 ECU
Old May 22, 2006 | 10:38 AM
QuarterMileMaster's Avatar
I don't see how that would work seeing how your ef is obd-0 and your da is obd-1. Although I have heard you can use your stock wiring harness to put an obd-0 LS motor in an ef.
Old May 22, 2006 | 03:17 PM
VtecMakesUGod's Avatar
u have to do some wiring cuz ur going from sohc to dohc. the wiring 4 the cam sensor is diff.
Old May 22, 2006 | 03:25 PM
rioninja's Avatar
Default Re: Is the true or not!!!! (VtecMakesUGod)
Your engine wiring harness will fit on the LS motor fine. It might be a bit tight in spots, but works perfectly. If you map sensor is on the throttle body on the LS motor (probably not), you will have to extend your map sensor wire.
For the computer, you can either use the (OBD1) 92LS ecu and distributor, and purchase a jumper harness for the ecu and distributor. (You can also repin the distributor plugs instead of purchasing a harness for that).
Alternativly, you can purchase an 90-91 OBD-0 ecu and distributor, in which case everything will plug right into your car. (or get your stock si ecu chipped with LS maps instead of buying the LS ecu).
Old May 22, 2006 | 05:00 PM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecMakesUGod &raquo;</TD></TR><TR><TD CLASS="quote">u have to do some wiring cuz ur going from sohc to dohc. the wiring 4 the cam sensor is diff.</TD></TR></TABLE>
He's refering to an LS, not a DOHC ZC. His problem is the OBD1 to OBD0 conversion which rioninja pretty much summed up the answer in a nutshell
jweeks
21
Sep 7, 2014 12:56 PM
Redline4Life
15
Apr 27, 2007 06:50 PM
shiftjdm
Northwest (Sales)
10
Nov 29, 2006 04:02 AM
b16ef4door
11
May 19, 2006 07:18 PM
Bseries!EF!hatch
May 19, 2006 08:24 AM
