DA Stuff EF Si PR4 Resistor Boxes VERY CHEAP
Everything is best offer. Don't hesitate to pm me if you have any questions. Help me clear out my garage!
90-93 Integra Adjustable Coilovers - $40
DA Integra Spindles With Calipers and Rotors and Arms - $90
DA Integra Ash Tray - $1
DA Integra Alternator 150 Miles on it Practically New - $30
DA Integra Calipers and Knuckles - $30
DA Integra Center Console Black - $10
DA Integra Gauge Cluster 81k With Harness - $40
DA Integra Cluster Wiring Harness - $2
DA Integra Driver Corner Light - $5
DA Integra Defroster Switch - $1
DA Integra Driver Headlight - $10
DA Integra Hazard Switch - $1
DA Integra Mudflaps - $10
DA Integra Driver and Passenger Power Mirrors - $20 Each
DA Integra Radiator Fan - $5
DA Integra Steering Wheel - $5
DA Integra Steering Column Cover - $1
DA Integra Window Crank - $1
B18a1 Cams with gears - $10
B18a1 Valve Cover (2) - $20
B18a1 Map Sensor - $10
B18a1 Throttle Body with Sensors - $5
B18a1 OBD-0 Wiring Harness - $10
B18a1 Spark Plug Wires - $20 (One set red, One set Black)
B18a1 OBD-0 Injectors Clean - $20
B18a1 Heat Shield - $2
1988-1991 Civic Si Brake Calipers - $30
1988-1991 Civic Si Driver Mirror - $20
1988-1991 Civic Si Master Cylinder - $30
Honda PM5 Civic DX ECU - $5
Acura OBD-1 PR4 ECU - $35
OBD-0 Resistor Box - $15
1999-2000 Civic Si Radio Pig Tails and plugs - $10
Kryptonite
Dec 16, 2002 08:12 PM
