95 auto tranny problem
Old May 22, 2006 | 09:55 AM
deeweezy187's Avatar
Default 95 auto tranny problem
I just noticed than when i'm driving my car revs to like 5 to rpm and then then shifts. When it does this i lift my foot off the pedal and press the gas again and it goes to driving normally. If just started doing like 10 mins ago. When i was on the highway and went into overdrive the engine redline mad times then goes. I hope its not time to get a new tranny cuz it so i am in trouble.
Old May 22, 2006 | 10:00 AM
Ross 2.0's Avatar
In a Junkyard near you.
First of all before you raced from your car to the computer you should have checked the fluid. If the fluid level is ok then you need to look at it's condition (reddish pink and stink free). If it's dark at all you need to have it flushed with Honda ATF-Z1.
If that is not the problem you may have a solenoid problem.
(also tell us if any dummy lights are on)
Old May 22, 2006 | 12:27 PM
Default Re: (MooGoCow3)
what is it supposed to smell like and when i turn the car off and restart it. I t starts to drive like normal than start back up again. and the fluid is not redish pinkish its brownish
Old May 22, 2006 | 12:42 PM
Ross 2.0's Avatar
You need to have it flushed with ATF-Z1. This may cure your broblem.
Old May 26, 2006 | 03:24 AM
NorCalCJ's Avatar
could bad tranny fluid also cause a delay in shifting? eg: shifting into reverse from park or shifting to D4 from reverse. It takes about 5 seconds before I can start moving.
Old May 26, 2006 | 04:07 AM
Ross 2.0's Avatar
absolutely.
It's just like having an inpurity (virus) in your blood. It makes everything act funny.
ThatOne02Accord
Dec 3, 2013 01:19 PM
moopsguitar
Jun 19, 2008 05:49 PM
OverCorrupt
11
Nov 11, 2005 10:35 PM
parker
Nov 13, 2004 08:45 PM
civicmon
Oct 29, 2003 03:24 PM
