HELP - Advice - Broken engine mount (on motor)
Old May 22, 2006 | 09:24 AM
psycho.chicken's Avatar
Default HELP - Advice - Broken engine mount (on motor)
Ok, 88 Civic HB, doing a B18A1 Swap.
Went to start prepping the motor and folund that someone broke one of the bolt holes on the motor, the one between the timing belt... so the motor is fubar'd...
Would of been a good motor too...
I found a B18B1... what would i need to do to put the B18B1 in the B18A1's place...
Keep in mind I have ALL the parts for the B18A1, ecu, axles etc...
Old May 22, 2006 | 09:27 AM
crxluv2's Avatar
Default Re: HELP - Advice - Broken engine mount (psycho.chicken)
You cant get the mount welded?
Old May 22, 2006 | 09:48 AM
Default Re: HELP - Advice - Broken engine mount (crxluv2)
It broke out the entire side of the bole hole, so if you look at the hole the bolt goes into, it's missing half the threats... bolt wont even stay in if threaded, just falls out...
Can i convert teh Motor itself (b18b1) to OBD0, usinf my B18A1's distributor and ecu?
sh!ft
Welding / Fabrication
Aug 6, 2011 09:45 AM
natovang17
Jun 18, 2009 08:44 PM
whitehf
Mar 3, 2006 02:44 PM
mkazm83
Jan 28, 2006 04:46 PM
Herminator
Oct 22, 2005 04:00 PM
