Squealing / screeching noise when accelerating with the air conditioner turned on
Old May 22, 2006 | 09:14 AM
rayho's Avatar
Default Squealing / screeching noise when accelerating with the air conditioner turned on
Whenever I accelerate on my 1999 4-door Accord LX, there's a squealing/screeching noise that comes out from the engine. If I let go of the gas pedal, the noise stops. This only happens during the first few revs AND when the air conditioner is turned on. The air conditioner runs perfectly fine and the car seems to be accelerating normally.
What seems to be the problem? Thanks!
Old May 22, 2006 | 09:22 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Squealing / screeching noise when accelerating with the air conditioner turned on (rayho)
Check to see if you belt is loose.
To check the tension, locate the part of the belt thats between the alternator pulley and crank pulley. Push on it with a decent amount of force and see how much it deflects. On a used belt it should deflect about 3/8" and on a new belt it should deflect about 1/4".
Also check for worn, dried, cracked and small stones in the grooves of the belt.
Old May 24, 2006 | 09:24 AM
rayho's Avatar
Default Re: Squealing / screeching noise when accelerating with the air conditioner turned on (TouringAccord
Thanks! I'll give it a try.
Old May 24, 2006 | 12:32 PM
JimBlake's Avatar
How old is the belt? Old belts get harder & a little more slippery. You have to over-tighten them in order to stop it from slipping. So maybe that's it, even if the belt LOOKS good & has no cracks or obvious damage.
MrsR
16
Aug 24, 2013 06:37 AM
accordcle
Nov 24, 2012 10:56 AM
YipMan_Style
Honda Civic (2006 - 2015)
Nov 5, 2007 09:51 AM
GSRpoweredSI
Jun 20, 2007 01:13 PM
Rick
Aug 25, 2003 05:18 AM
