How to fix rounded head Bolts?? Need HELP!!
Im loosening the tensioner bolts in the timing belt area and for some reason the head of the bolt is rounded. Im using 14mm socket and there is no use because its slipping already when i tried to loosen. Can you guys help me how to loosen the rounded bolt so that I can put on my new timing belt. Really appreciate it for your help. Thanks!!!
Modified by 2civic3 at 10:34 AM 5/22/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">craftsman has a strip bolt tool works like a charm. costs like 50 bux</TD></TR></TABLE>
^^ an essential addition to any tool set
6 point impact 1 size smaller or there method but if you had a wleder weld a nut on top or extractor set. or vise grips
be careful with those
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slikz »</TD></TR><TR><TD CLASS="quote">Tada.
http://www.sears.com/sr/javasr...e=Yes </TD></TR></TABLE>
my personal choice for removing rounded off bolts
White91EF
Nov 1, 2022 07:26 PM
