whats the best turbo on a d15b vtec
Old May 22, 2006 | 02:03 AM
zenon8890's Avatar
Default whats the best turbo on a d15b vtec
i'm boosting my crx, i just wanna run a tight turbo on the stock engine, whats the best one that wont blow up my engine, and also give me a good HP.
i was thinking about the mitsubishi td04 or td05
Old May 22, 2006 | 03:47 AM
ham's Avatar
ham
Default Re: whats the best turbo on a d15b vtec (zenon8890)
definitely a 14b. they are cheap, durable and easy to find.
Old May 22, 2006 | 10:36 AM
big-cat's Avatar
a turbo that wont blow ur engine? it sounds like u need to do more research, no offense but u can put any turbo u want on that motor and it wont blow if the psi is low enough and the engine is running right. not trying to be a dick but maybe that question was just to bland and u do know what, what u are talking about.
I would recomend a t25, g28r, t3,t04e. depends what u are looking for
Old May 22, 2006 | 12:28 PM
zenon8890's Avatar
i want a stock boost, i dont want more than 200hp, and i dont want 200 actually but it will be nice, i wanna ask about fuel management, what should i get for that?!
Old May 22, 2006 | 12:33 PM
mrbsponge's Avatar
14B or 16G is fine,
as for management, convert to OBD1 and get crome or hondata or something along those lines
Old May 22, 2006 | 12:46 PM
zenon8890's Avatar
Default Re: (mrbsponge)
well i tried to convert obd1 many times it didnt work, i still have all the obd1 parts (ecu, dizzy, conversation harness).
i didnt have spark and the car didnt start
any other way to use obd0?! FMU?
Old May 22, 2006 | 01:11 PM
big-cat's Avatar
i would say go with a t3. if you want a pretty good amount of power yet not enough lag to annoy u in everyday driving. t25 is practically imediate boost. t3/t4 is huge amounts of boost but mucho lag, not so hot for everyday driving
Old May 22, 2006 | 01:37 PM
nonvtecD's Avatar
TurboEdit is a freeware program for obd0. It sounds like you need to read some more, how hard is an obd1 swap...
Old May 22, 2006 | 02:04 PM
JDM-Civic-Hatch's Avatar
i used a t3 super 60 from phoenixturbos.net and it hit 9 lbs full boost at 3800.
now im on diff setup. fully built on t3/t4
Old May 23, 2006 | 10:32 AM
zenon8890's Avatar
Default Re: (nonvtecD)
the obd1 conversation is not easy as everyone's write it, i tried it alot but didnt work, i have turbo edit software on my pc, just how will i use that? i downloaded a few ROMS for a couple of programs like mine
Old May 23, 2006 | 12:01 PM
Tad's Avatar
Tad
was bout to say 14b also
Old May 23, 2006 | 01:33 PM
nonvtecD's Avatar
Default Re: (zenon8890)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zenon8890 &raquo;</TD></TR><TR><TD CLASS="quote">the obd1 conversation is not easy as everyone's write it, i tried it alot but didnt work, i have turbo edit software on my pc, just how will i use that? i downloaded a few ROMS for a couple of programs like mine</TD></TR></TABLE>
You burn a chip or get someone to burn you one and then someone with a wideband can tune you...
Old May 23, 2006 | 03:17 PM
zenon8890's Avatar
i can let someone to burn the chip for me, so i can use turbo edit ready ROMS and burn it into a chip right?
Old May 24, 2006 | 06:01 PM
nonvtecD's Avatar
yep
Mrpepper116
Honda Civic (2001 - 2005)
60
Jun 20, 2010 09:29 AM
schock3
Engine Management and Tuning
Jul 25, 2009 05:53 PM
animeFrank
Jun 15, 2008 12:48 AM
mini-cRx
Feb 18, 2002 04:34 PM
