Steering wheel lock broken
Old May 21, 2006 | 09:19 PM
Flatland2D's Avatar
Default Steering wheel lock broken
My car was stolen a week and a half ago and it turns out they busted the steering wheel lock. The turn signals and wiper blade controls are now canted to the left. Is there any way to fix this? I would like to have the steering wheel lock back but I guess it doesn't matter if it breaks so easy. I just want my control sticks parallel to the floor again. I'm not familiar with this area of my car so any help would be appreciated.
Old May 21, 2006 | 09:30 PM
sohcvtec1995's Avatar
I would like to know this as well. Is there a way to repair it or do you have to replace the whole thing.
Old May 21, 2006 | 11:47 PM
thahuhstunna's Avatar
Default Re: Steering wheel lock broken (Flatland2D)
those are broken so that the thieves could steal the vehicle... my advice would be to get used to it, as i have with my salvaged vehicles sorry to hear about the theft man, hope it doesnt happen again
Old May 22, 2006 | 06:10 AM
Flatland2D's Avatar
Default Re: Steering wheel lock broken (thahuhstunna)
I don't mind the wheel lock being broken but is there any way to rotate the steering column controls so they are level again?
Old May 22, 2006 | 06:57 AM
EK79's Avatar
these can be replaced the cost depoending on car is around 150 dollars at local honda dealership. the only set back is when you replace the steering wheel lock yuou replace the ignition key which wont match to the door or trunk (speaking from experience)
easy fix but pain in the *** ........hope this helps
Old May 22, 2006 | 07:56 AM
CTRwannaB's Avatar
Default Re: Steering wheel lock broken (stoopid monkey)
wut year u got?
i got all those parts needed to replace it
its from a 99si tho
Old May 22, 2006 | 08:48 AM
saywhat's Avatar
Default Re: Steering wheel lock broken (CTRwannaB)
You can straighten your column with some pliers if you tear apart the the column and take everything off including the wheel, you drop the column separately from the tilt mechanism and there are two sides that are going to be bent, just use the pliers to straighten them. Hard to explain, I will do a write up next time I fix one.
c|rop3asy==[]
11
May 26, 2013 03:38 PM
Danielsb20crx
39
Jan 6, 2013 01:02 PM
JDM_EK_JOE
10
Apr 15, 2006 10:59 PM
ludedudeh23
Oct 29, 2004 04:33 AM
