5th Gen Fuel filter
oh man this is a bitch with the motor in the car. **** i had a hard time with it out
. you have to hold the nut the connected to the fuel line. it a bitch. then somehow turn the filter.
ummmm..you should be able to do it from the top. i never heard of needing 2 people for th job. what i would do is try to wedge a wrench in somewhere to hold the nut on the line. so when u turn it it dosent move. the just turn the filter. does that make sence??
yeah i read that but i dunno how to put it to use so i didnt buy one
i should have of just taken my damn car to the shop for this ****.
see that's wut i thought at first when i first tried it. but than i just kept working at it. 2 days of work couldn't get it out. then i went and bout the $5 dollar craftman crowfoot and got the job done in less than 45 min. here's a link that will deff. help!
http://www.solarshadetruckpara...r.pdf
don't do wut the picture does because u still wont be able to go from underneath. get a 14mm crowfoot adapter and put it on a 8 inch extention. than put a 3/8 ratchet on it and since ur working basically upside down on the bolt..so on the ratchet..loose is going to be tight and tigh is going to be loose. hope this helps. maybe i'll do a how to later...
hey thanks a ton that diagram helped alot i guess im going to TRY to put this stupid **** back together tommrow morning really early and get the right tools.
nk2k2
Oct 25, 2005 12:03 PM
