Need a Diagnosis
Old May 21, 2006 | 06:04 PM
Topnotcheez's Avatar
Default Need a Diagnosis
Here's the problem. Every time I park my car (or slightly turn my steering wheel, I hear a squeek come from my front wheel). The noise sounds like an old door hinge that needs oil or something. The squeek stays on as long as I have the wheels turning (left or right). Any know what the problem may be (if I ignore it, will I be hating myself later?) This is for a 2000 RL...but I figure this could be for any car.
Old May 21, 2006 | 06:12 PM
jagged4698's Avatar
Default Re: Need a Diagnosis (Topnotcheez)
Well if i understand what you explained correctly it seems like the noise is happening when you hold your steering wheel all the way one direction... If that is the case that would have something to do with the powersteering system. I would first start by checking the fluid level of your power steering fluid and adding as needed. If that looks to be ok i would then check the belt that is on the power steering pump. Check for signs of wear and to see if the belt may be loose.
Old May 21, 2006 | 06:15 PM
Default Re: Need a Diagnosis (jagged4698)
Actually, the noise starts anytime I try to turn the wheel. It doesn't necesarry happens when I cut it all the way to the right or left. It happens when I turn or add the slightest pressure to the wheels.
Old May 21, 2006 | 07:53 PM
blueshark's Avatar
The power steering resivior(Where you would add fluid) also contains a filter. If this filter becomes restricted the pump will strain and cause a harsh noise. Also if the rack tension is to tight this can cause the problem.
transitions
Honda Civic (2006 - 2015)
Oct 4, 2011 06:43 PM
Black Ack
Dec 6, 2006 03:36 PM
mrmonk
Nov 17, 2003 10:29 AM
x00gsr
Dec 16, 2002 02:55 PM
imported204
Apr 26, 2002 06:42 AM
