What sort of parts are involved in a engine overhaul?
ACL bearing set: $60
Rings: $100 http://www.majestichonda.com
Head Gasket: $60 http://www.majestichonda.com
Machine Work: It depends what needs to done.
Check out head too.. Replace valve seals, they are cheap.
Water pump, oil pump, rear main seal...
Doesn't cost much.
Doesn't cost much.
For the upper and lower gasket kits from Baranco for my car I paid 237.08 w/e shipping.
06110-P72-060 GASKET KIT, CYL HD 1 1998 INTEGRA 187.62
06111-PR4-020 GASKET KIT 1 1998 INTEGRA 49.46
Are you doing a stock rebuild? I know one member did a stock spec rebuild w/new pistons, oil/water pumps and it came out to ~$3400. My rebuild cost quite a bit more w/some after market parts. If you have the knowledge to do everything yourself you will save yourself a big chunk of change. Otherwise be sure to have enough money to complete everything, you don't want your car sitting idle while waiting for funds! Good luck!
its really depends if your gonna just rebuild the engine OEM or if you want to build it for performance...you probly spen $800-$100 if you do everything yourself. on all brand new OEM parts..pistons, gaskets, honing if needed, oil pump, water pump, etc etc
Vagitarian
Sep 13, 2012 06:40 PM
QuarterMileMaster
Jan 28, 2009 06:54 PM
