b16a2 swap, half of del sol cluster not working
Old May 21, 2006 | 05:19 PM
diko's Avatar
Default b16a2 swap, half of del sol cluster not working
i recently inherited a del sol with a b16a2 swap. great motor and the car runs great. unfortunately the cluster doesnt work completely. the speedo and tach do not work, only speedo lights up when lights turned on. CEL light does not come on, and cruise control does not work. i took the cluster and placed it in another del sol and everything works when swapped. im afraid to get into an electical tracing nightmare. where do i start? if i can get the tach and speedo working, the rest is trivial... someone please help or point me in the right direction. TIA
diko
Old May 21, 2006 | 06:41 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: b16a2 swap, half of del sol cluster not working (diko)
Check your fuses.
Old May 21, 2006 | 08:05 PM
diko's Avatar
is there a fuse strictly for the tach and speedo? i will check tomorrow, unless someone knows the quick answer...
Old May 22, 2006 | 12:37 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: (diko)
It only takes less than 5 minutes to check.
Old May 22, 2006 | 12:59 PM
fmrprojects's Avatar
Default Re: (NVturbo)
check to see if the VSS is plugged up. and if the cruise control is even hooked up. but the cruise control needs VSS signal to work
cfauvel
Aug 10, 2015 11:38 AM
birdwellington
Oct 20, 2006 05:30 PM
diko
Jul 22, 2006 10:48 PM
Chris.
Sep 29, 2005 07:40 PM
Crank
42
May 12, 2004 07:29 PM
