89 dx rex ?'s
If I get this
http://hmotorsonline.com/shop/...30003
do I still have to get 90-93 throttle cable, 2nd o2 sensor, vetc pressure switch, olenoid and a knock sensor or do they come with it
can someone just tell me what else I would need
I can only answer for the VTEC pressure switch, and if if the motor comes with the pressure switch then use it. If it doesn't then you can splice some wires extremely easy) and you'll be fine. It also depends on what ecu you use.
u realize that swap is obd1.? so no 2nd o2 sensor is needed..but you will have to wire in 1 4 wire o2 sensor into your harness,,as well as convert your engine wire harness and ecu clips and to obd1..and also convert to multil point fuel injection..
alright here a list of everything you need, i think. i just got my b16a1 for my 90 si crx, but since my is a si it already had multi port.
swap mount
shift linkage
90 integra clutch throttle and speedometer cables
you need to do the wiring for multi port i suggest sending the harness off to rywire
and if you do get the xsi b16a you'll need a jumper harness for obd-o obd-1 convertion.
i just got my swap off the truck friday i haven't even put it in. but shop around i got my b16a for 1500 thats including shipping from japanmotorimport.com very pleased so far.
the lonely problem i have had is the swap didn't come with axles
swap mount
shift linkage
Hondamonster
Jun 6, 2007 08:04 PM
