Bseries motor mount question
Old May 21, 2006 | 03:16 PM
mahatma's Avatar
Default Bseries motor mount question
Whelp this should be easy:
Driver's side motor mount. Has 1 stud sticking up, and 1 hole. The aftermarket mount lines right up, but the stud isn't threaded all the way down.....
So when I try to bolt the mount on, the nut only goes to the bottom of the threads and won't secure the mount.....
Is there a spacer or something else that goes here??
thanksalot
Old May 21, 2006 | 05:23 PM
SD_Lurker's Avatar
HT White Ops
Default Re: Bseries motor mount question (mahatma)
Sounds me like you have a washer missing. It would also help a ton if you told us what mounts you have.
Old May 21, 2006 | 05:47 PM
Crx Jimmy's Avatar
i took the one stud off the d series mount and put it on the new B motor
Old May 21, 2006 | 06:37 PM
mahatma's Avatar
Default Re: Bseries motor mount question (Crx Jimmy)
HCP mounts I think. I don't remember any washers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">i took the one stud off the d series mount and put it on the new B motor</TD></TR></TABLE>
aha! So does it just hammer out?
Here's a pic of what I'm talking about.
This is not my car or mounts, but it's the top stud there.
^ Thanks to the pic donor
-=ZAK=-
Dec 1, 2008 03:46 PM
RustyE.G.
Dec 12, 2007 04:36 PM
keaps206
Jun 11, 2006 01:48 PM
bbrian
Jan 25, 2006 11:10 PM
