NEED INFO!!! Swapping 2000 D16Y8 Into 91 MPFI CRX What ALL DO I NEED!!!
Old May 21, 2006 | 02:58 PM
white91crx's Avatar
Default NEED INFO!!! Swapping 2000 D16Y8 Into 91 MPFI CRX What ALL DO I NEED!!!
I am swapping a 2000 D16y8 into my 91 mpfi crx. Already have it in my 92 hatch but decided to put it in the rex, I am running a p28 ecu with the engine. Other than the boomslang harness is there anything else that I will need to get the swap up and running. I want to stick with the crx cable tranny instead of converting it to hydro so will the D16A6 tranny bolt up to the D16Y8. If anyone can help me out I would greatly appreciate it.
Old May 21, 2006 | 06:15 PM
HondaCivicSiR1's Avatar
Default Re: NEED INFO!!! Swapping 2000 D16Y8 Into 91 MPFI CRX What ALL DO I NEED!!! (white91crx)
ok you will need the all of the stock mounts from the d16a6 and you will need to use the shift linkage,flywheel,pressure plate and clutch disc and axels for the crx cable trans and then you will need to wire the car for vtec,oil pressure switch feel free to pm me if you have anymore questions
Old May 22, 2006 | 01:28 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: NEED INFO!!! Swapping 2000 D16Y8 Into 91 MPFI CRX What ALL DO I NEED!!! (HondaCivicSiR1)
If you need the wiring for the car check out my store. I have done a similar swap in my 89 CRX Si so if you have any questions PM me or email me at hondapartshero@aol.com.
SilviaSliderNj
Apr 7, 2008 08:38 AM
SmobbinSi
Nov 8, 2006 09:20 AM
turizmoj33
Dec 10, 2003 11:04 AM
mark420
Jul 21, 2003 09:12 AM
one slow d16
Mar 11, 2003 09:16 AM
