Wiring Amp for '97 del sol
Old Apr 12, 2002 | 12:04 PM
pushupbra's Avatar
Default Wiring Amp for '97 del sol
Hey. I'm new here. I would like to install my amp in the trunk seein as there is no other place to put it. How do you guys suggest I wire the power, remote, and rca cables. Should I go through the center console to the trunk? I guess I tryin' to find out where I should run the wires. Your help would be appreciated. Thanks.
Old Apr 12, 2002 | 12:06 PM
JV's Avatar
JV
Who?
Default Re: Wiring Amp for '97 del sol (pushupbra)
Wrong forum........
Try here
https://honda-tech.com/zeroforum?id=27
Old Apr 12, 2002 | 12:47 PM
Russ713's Avatar
dAng!
you can go underneath the center console, remove the rear panels and console. there are holes on the side that will allow you to gain access to the rear trunk area.
Old Apr 12, 2002 | 01:29 PM
my2ndtool's Avatar
the pas side has the biggest hole but you can go both sides
I have two behind the seats and a box in the back lip 2 6in jlaudio
make sure if you go on that back wall dont use long screws you will scratch your window.
patrick
94 del sol vtec
Old Apr 12, 2002 | 01:39 PM
3.3.3's Avatar
Default Re: Wiring Amp for '97 del sol (my2ndtool)
i had mine screwed into the trunk area (where the cover originally for the spare was). but my trunk was stripped.
94delsiblk
Oct 18, 2009 05:51 PM
skUnK2jdm
Aug 23, 2007 01:03 PM
Dumbquestions
Audio / Security / Video
10
Nov 23, 2005 05:41 AM
deconstruct
Feb 25, 2005 08:12 AM
